Driven5
Driven5 Reader
12/9/13 5:50 p.m.
ProDarwin wrote: Also note that 99% of RWD stock-class autox cars run a larger front swaybar to mitigate understeer.
ProDarwin wrote: Well, most prepped stock-class 350Zs are running a bigger front bar.
Correlation does not imply causation.
Also note that up through 2011, stock class autox rules only allowed the front bar to be changed. It wasn't until 2012, with most chassis already having heavy development of larger front bar setups, that the rules were opened up to allow either (but only one) bar to be changed. Thus the running of a larger front bar in no way, shape, or form implies that it was actually being done specifically to mitigate understeer on modern RWD sports cars...Only that it was a product of bygone vehicle dynamics that still was able to ultimately improve lap times, regardless of what other side effects it had or what else could be done within the rules (square tire setup) to help balance out the larger front bar.
If speaking in general terms, most of the time a larger front bar should increase understeer. In certain specific circumstances, a larger front bar can decrease understeer...But it is incorrect to imply this as the more common scenario.
Unless the car has a noticeable rear weight bias or extreme power, I would tend towards a square tire setup. If you do choose to go with a square tire setup, a larger front bar may also be beneficial to rebalance the suspension from the additional front grip.
Cone_Junkie
Cone_Junkie SuperDork
12/9/13 5:53 p.m.
One more vote for square tire setup.
Worked well on the 240SX that's for sure.
Spoolpigeon
Spoolpigeon SuperDork
12/9/13 10:17 p.m.
Square tire setup for sure, check suspension components for wear/play, get an autocross oriented alignment, then report back to us.
Spoolpigeon
12/9/13 10:19 p.m.
In reply to evildky:
Take mine for a run at the next event. You'll like it
evildky
evildky Dork
12/10/13 11:41 a.m.
Spoolpigeon wrote: In reply to evildky: Take mine for a run at the next event. You'll like it
Careful, people who offer me co drives in s2k's have a way of disappearing or having constant car issues (Chris G and Marc P.)
Spoolpigeon
12/10/13 4:46 p.m.
I wondered what happened to Granger lol
evildky
evildky Dork
12/12/13 10:59 a.m.
In reply to Spoolpigeon: he got married
YCzi6mrTSi5mxc2SiGbk2QnAOblqRTaeNmlDl8gB9T72S9alTuKyFK1iqR5olPWF
