Will
Will HalfDork
6/26/10 4:37 p.m.
I want to add a Lexan spoiler to my 4th-gen Camaro ESP autocross car. Anyone have any tips on how to build and mount a simple blade-type spoiler?
maroon92
maroon92 SuperDork
6/26/10 5:19 p.m.
mock up with cardboard. make smooth cuts. sand down the edge for uniformity. make sure you have turnbuckles that will support the air, as well as provide adjustability.
Will
Will HalfDork
6/26/10 5:33 p.m.
What's the best way to actually fasten it to the decklid?
maroon92
maroon92 SuperDork
6/26/10 5:36 p.m.
either fabricate angled brackets, or you might be able to use a solid mount hinge...
Giant Purple Snorklewacker
6/26/10 7:48 p.m.
Apparently, all you need to do is ask me to make a window out of it and you will get a pile of spoiled lexan approximately equivalent to the amount of unspoiled lexan sheet you originally had.
hotrodlarry
hotrodlarry Reader
6/26/10 8:05 p.m.
Why get all fancy.
I made a lexan rear spoiler for a oval track car out of a piece of lexan, two screen door hinges and a couple pieces of aluminum bracket of a conveyor belt.
Pretty sure it cost me less than $10 to make. One trip to Home Depot for the hinges, and the lexan and brackets were free.
I also drilled a couple extra holes in the body so I could adjust the angle. everything was held together with 1/4-20 bolts
maroon92
maroon92 SuperDork
6/26/10 8:55 p.m.
Make sure you use LEXAN...
I once cheaped out and got some off brand crap, it broke in a day.
pedretti
pedretti New Reader
6/26/10 9:18 p.m.
if not lexan, alternatives include sheet metal (steel or aluminum) fiberglass(if you want to put more time and money into it, and choroplast if your not looking for a long lasting solution/good looking solution
mw
mw HalfDork
6/26/10 10:29 p.m.
Lexan can be bent in a brake. You could just bend a flange and use big rivets to fasten it to the trunk. Then use supports to make it strong.
NYG95GA
NYG95GA SuperDork
6/26/10 10:37 p.m.
The turnbuckle and hinge idea is pretty good thinking. You may decide to change the angle later on.
Depending on the data you get back after the wind tunnel tests..
RXBeetle
RXBeetle Reader
6/26/10 10:38 p.m.
Any real polycarbonate will be fine. Lexan is just GEs name for it. Do NOT get petroleum stuff on it, it will get brittle in no time. A wood planer, the manual kind, works great for cleaning and straightening up wavy saw cuts. Polypropylene should also be sufficient at much lower cost. McMaster.com part# 8742K632 $16.33 and should be enough to screw one up. PETG should also be a cheap alternative (similar to plastic bottle material).
patgizz
patgizz GRM+ Memberand SuperDork
6/27/10 9:16 a.m.
i had this thought the other day - thinking of adjustable spoilers with turnbuckles while thinking i wanted to find something huge from the 60's and do a vintage stock car look alike.
piano hinge - it will give support across the whole front edge and they come in all kinds of finishes. it would work well on all but really curved surfaces.
nsBMkrzGcJohynKkVKRLB7FyIRjlGpAblDmmKd1WvCo0bXdBS2WbyR4qoQSzOtWZ
