SVreX (Forum Supporter)
SVreX (Forum Supporter) MegaDork
2/3/21 7:04 p.m.
In reply to Stampie (FS) :
Don't care much about OSHA.
My issue with using a table saw is if the machine has ever been used to cut wood (duh), then there is sawdust one the bottom cabinet. Grinding wheels throw sparks- fire hazard.
Additionally, many of the sparks will fly up. I'll bet you didn't use a guard for this particular operation, because if you had, it would have melted.
There is no reason to attempt this with a table saw when the exact same thing can be accomplished with a skillsaw (without those risks).
Also, 13" dia is a little small to attempt with a 10" blade. It's easier with a 7 1/4" blade (and even easier with a jig saw blade)
2/3/21 7:07 p.m.
In reply to Mr_Asa :
If it has a pilot hole in the center already, then all of the above listed cutting tools (router, jigsaw, skillsaw, bandsaw, etc) could be used accurately with a guide rod bolted through the pilot hole.
Easy Peazey.
Woody (Forum Supportum)
2/3/21 8:44 p.m.
Do you have access to a plasma cutter?
https://www.eastwood.com/eastwood-plasma-cutting-guide.html
Probably not, but maybe you could adapt this sort of idea to a sabre saw.
93gsxturbo
93gsxturbo SuperDork
2/3/21 8:50 p.m.
Waterjet...
Crackers (Forum Supporter)
Crackers (Forum Supporter) SuperDork
2/4/21 7:34 a.m.
In reply to SVreX (Forum Supporter) :
I'd be more worried about the cutting wheel loading up and shattering than all those aluminum sparks.
2/4/21 9:56 a.m.
In reply to Crackers (Forum Supporter) :
On a table saw?  Yeah, you're probably right.
yNmY1nQC53OYP0gRVmg9FMo7EUAaPoHtx3p7UNvJUOW7OU1a11kEvgWqiUXLzrQ0
