Per Schroeder
Per Schroeder PowerDork
3/9/22 2:22 p.m.
[Editor's Note: This article originally appeared in the October 2009 issue of Grassroots Mototsports.]
For most of the motoring public, picking the right oil is easy: Simply follow the manufacturer’s recommendation. No matter what the make and model, trusty engineers have already determined the right viscosity for that particular car. Whether it’s 5W30 or 10W-whatever, the information is in the …
bobzilla
bobzilla MegaDork
3/9/22 2:38 p.m.
If only we had a member here who offered those types of services.
jharry3
jharry3 GRM+ Memberand Dork
3/9/22 3:34 p.m.
RE cold temps causing problems while using 20W50.
I was running 20W50 in an "enhanced" 289 in a '65 Mustang.  Once morning it was 25 degrees F; unusual for the city in the Deep South where  I lived.   I started the engine and it blew out the seal on the oil filter.  The oil pressure gauge, a real one with a small copper tubing routed to the engine, went all the way left for an instant then went to zero when the blow out happened.    And I quickly shut off the engine at that point.
WillG80
WillG80 GRM+ Memberand Reader
3/9/22 9:38 p.m.
Bobzilla, do your services include HDEO recommendations? I'm curious if I can still run Delvac, Delo or Rotella T4  dino oils in my 7.3 and 6.0 diesel since they're not on the approved Ford diesel oil spec (WSS-M2C171-F1) anymore. Apparently something about the CJ-4/CK-4 spec change. Am I just overthinking this?
nothing like a good ol oil thread...
deaconblue
deaconblue New Reader
5/6/22 2:19 p.m.
Choosing thr correct weight oil is a function of:
block material
rod material
bearing clearances
expected oil operating temperature range
I use the chart below and consult with the shop that builds the short block to make sure we are using the correct weight oil.
grover
grover GRM+ Memberand Dork
5/6/22 9:32 p.m.
Now that this decade is over a decade old, I'd love to see Bob in an article talking about Oil, would also be neat to honor a member's business.
bobzilla
bobzilla MegaDork
5/6/22 10:06 p.m.
Things have been a bit crazy the last couple months and I completely missed this. PM me and I'll do my best to answer any questions you got.
bobzilla
bobzilla MegaDork
5/6/22 10:08 p.m.
I appreciate that. I missed one from March in here.  Silly day job making me miss things.
grover
5/6/22 11:34 p.m.
Day jobs are lame, I can relate.
4VOjtJwMKACyzkBmsul28T8lyGQ8LOgoe1t8MCSuHo46XnrJBUrfwNZVawAdsQE6
