Armitage
Armitage Reader
6/19/11 5:35 p.m.
I'm having a problem with the copious amounts of dust left behind by these Hawk DTC-60 race pads after a track weekend. If it rains, and it always seems to, the dust, which I suspect is more bits of rotor than pad in the first place, forms an everlasting friendship with the polished and painted surfaces of my wheels. It looks like I have 1/16" of rusty growth on all the spokes and the lip. The only thing abrasive enough to remove it is scotch brite and tons of elbow grease but I don't want to ruin the finish. Any other ideas how to remove this stuff? Spray on wheel cleaner is useless as are all the other cleaning agents I've tried. Thanks!
ansonivan
ansonivan Dork
6/19/11 5:44 p.m.
Wheel acid or diluted muriatic acid which can be found at Lowes. Wipe it on, leave it for a few minutes and rinse it off. Use a tooth brush to agitate and multiple applications as required. I use a rag to wipe it on as it will kill spray bottle pumps in short order.
This will corrode any exposed steel or aluminum so its a good idea to experiment on one wheel before diving into a huge mess.
iceracer
iceracer Dork
6/19/11 6:17 p.m.
I have had good luck with car wash and a scrub brush.
jimbbski
jimbbski Reader
6/19/11 6:28 p.m.
phosphoric acid
Look for products that contain this. Do not use muriatic acid, while it does a good job removing rust from steel and etching concrete phosphoric acid is much safer to use and will also remove rust stains and etch concrete. Muriatic acid fumes are nasty and it can cause chemical burns where most products that contain phosphoric acid and be used and disposed of down most city drains. Heck, it's even used in some foods in small amounts.
paul
paul Reader
6/19/11 7:29 p.m.
Any good sealants/waxes out there to help deter future dust adhering to rims?...
ansonivan
ansonivan Dork
6/19/11 7:59 p.m.
Jim, have you found any local sources for phosphoric acid? I've heard the same things but have yet to located the stuff.
fasted58
fasted58 HalfDork
6/19/11 8:10 p.m.
naval jelly (phosphoric acid), but it will harm paint, maybe wheel paint not so much
DavidinDurango
DavidinDurango New Reader
6/19/11 8:26 p.m.
Coca Cola.
ansonivan wrote: Jim, have you found any local sources for phosphoric acid? I've heard the same things but have yet to located the stuff.
amg_rx7
amg_rx7 HalfDork
6/19/11 11:55 p.m.
I used some Meguiars All Wheel Cleaner and a tooth brush. http://www.meguiarsdirect.com/product_detail.asp?T1=MEG+G9524
I have also used some simple green and hard sponge in soapy water to rub off the difficult stains on the wheels and paint. Seems to have worked for me on my Spec Miata on Team Dynamic silver wheels.
Claying the paint also helped a lot. I used some wheel wax on the wheels also after the first rain race where I had to clean all that crap off my wheels and car.
Yes, I'm running DTC 60 pads. White car.
e_pie
e_pie Reader
6/20/11 12:34 a.m.
Meguiars All Wheel cleaner and a little elbow grease has always worked for me.
iceracer
iceracer Dork
6/20/11 10:12 a.m.
Non-stick cooking spray,aka:PAM, unflavored will help. Applied before, not after.
jimbbski
jimbbski Reader
6/20/11 10:45 a.m.
jimbbski wrote: phosphoric acid Look for products that contain this. Do not use muriatic acid, while it does a good job removing rust from steel and etching concrete phosphoric acid is much safer to use and will also remove rust stains and etch concrete. Muriatic acid fumes are nasty and it can cause chemical burns where most products that contain phosphoric acid and be used and disposed of down most city drains. Heck, it's even used in some foods in small amounts.
Your local Lowes's, Home Depot, or Menards is the place to buy it. Look at products like "Lime Away", or concrete etching, or concrete cleaning. The following is a link to info on one such product. Click on the MSDS sheet and you will see that it containes phosphoric acid. It can also be used to clean aluminum. When dulitied it is safe on most paints it just may take longer to clean.
http://www.krudkutter.com/cleanandetch.asp
fQ6Cft0JJ7xLXdiwh52SN9rrMZyJXflHh9ftdYa7WHRvYUymm8vHef0vxTijBBM4
