Scott Lear
Scott Lear
7/20/18 8:48 a.m.
Like stories like this? You’ll see every article as soon as it's published by reading the print edition of Grassroots Motorsports. Subscribe now.
1. Loop the old accessory belt around the crank pulley.
2. Run both sides of the belt over an available accessory pulley.
3. Anchor the other end of the loop on a third pulley.
4. Rotate the crank pulley and take up the belt slack by letting the crank pulley end pinch the belt under itself.
<b5.
When the last of the slack is gone, the belt should immobilize the crank pulley completely, allowing you to apply gobs of bolt-loosening torque.
IAdUHsJms6cmfOGsHHWAvLmR6YIpVYRRQml4bBZ5iKLA3uDz80WllzdKtS3joRjN
