DrBoost
DrBoost PowerDork
10/28/13 7:15 a.m.
aussiesmg wrote: I have a garage oven, I just bought the Harbor Freight media blaster, now I am looking for an Eastwood powder coater. I have several sets of wheels to do first. Anybody got leads on custom powder colors?
I don't have any personal experience with any of these other than the eastwood powders that came with my kit:
Eastwood powderbuythepound caswellplatings prismaticpowders (this place allows you to order hunks of aluminum already coated to sample the colors, mine are in the mail)
DrBoost
DrBoost PowerDork
10/28/13 7:17 a.m.
Toyman01 wrote: Naturally, I carefully measured to make sure it was wide enough for a 17" wheel. Too bad I didn't check the depth. I had to do a little modifying to the door to get enough room.
I keep meaning to ask you. What did you do to get the wheel to fit? And before your measurement, do you remember how deep the oven was?
I'm asking because I'm buying an oven this week since I have a paying customer right now. I'd like to be able to do wheels and the only measurements I have were of the oven I took.
On a side note, since I've been going PC crazy the last few weeks you should have seen, heard, and felt my wife's reaction when she saw me taking a tape measure to the inside of the oven
Toyman01
Toyman01 GRM+ Memberand UltimaDork
10/28/13 9:00 a.m.
In reply to DrBoost:
The door and glass was double walled and about 6 inches thick. I removed the inner wall and glass with a grinder. I'll try to remember to shoot a picture when I get home this afternoon.
DrBoost
DrBoost PowerDork
10/29/13 7:17 a.m.
So I found an older double oven on CL for $50. As long as it all works I'm going to jump on it. I'd like it to be a bit bigger but I'll make do. It's 17 3/4 wide - 17 3/4 tall - and 20 deep (top oven). I figure it's a good idea because I have the toaster oven for small things like brackets, the bottom oven for medium items, and the top oven for larger items. Not that I need that, but no sense in heating up the big oven for an alternator bracket.
aussiesmg
aussiesmg MegaDork
10/29/13 9:07 a.m.
I ordered this one, just ordered several 1lb bags of powder as well, I haz some playing to do next week.
http://www.ebay.com/itm/360772152913?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
I already have a Craigslist special oven in the shop
I am planning on doing some rims first
DrBoost
DrBoost PowerDork
10/29/13 11:41 a.m.
Sweet aussie. That's the one I wish I'd have gotten. Mine has only the one power setting. Not sure if I'd ever need two settings, but because I didn't get it, I'm sure I'll need it.
I have a question for toyman. Did you install your double oven, or just set it on some blocks or something? I would like the double oven I found, but if it means spending a saturday building a frame to put it into, I'll pass.
I don't see any reason why you can't just set it on 4 cinder blocks or something, then run a metal strap to the wall so it doesn't topple over.
aussiesmg
aussiesmg MegaDork
10/29/13 12:09 p.m.
You definitely motivated me, having an oven helped.
I know I will be building a bigger oven soon.
Toyman01
10/29/13 12:25 p.m.
Mine is flat on the bottom and has no problem standing up by itself. It's sitting on the floor against the wall. All the powder coating stuff is stored inside it.
DrBoost
DrBoost PowerDork
10/29/13 12:46 p.m.
Toyman01 wrote: In reply to DrBoost: Mine is flat on the bottom and has no problem standing up by itself. It's sitting on the floor against the wall. All the powder coating stuff is stored inside it.
Good, thanks. I'm going to get the double oven then. It's an old one, but that tells me it's reliable with no expensive computer boards to crap out on me.
Aussie, make sure to post your results here. I want to be able to do wheels too. I'd like to be able to do 18's, and that might be possible if I do the mod that toyman did.
aussiesmg
aussiesmg MegaDork
11/1/13 7:32 p.m.
I got my powder coating kit yesterday and opened it today.
Moved it and my portable air compressor nearer the oven.
I got my fresh A arms today, in bare steel. What do you do to prep the metal before coating it?
They are shiny and show no rust at all.
Pics will be posted after I screw it up royally or do the best job evar, which is somewhat less likely.
Toyman01
11/1/13 8:15 p.m.
For prepping them, I'd make sure they don't have some kind of rust preventive coating on them. If so, blast them. Then I'd wash them down with brake cleaner to get rid of oils. I'd throw them in the oven at 250 for 30 minutes, to make sure all the solvents are evaporated and then coat them. That's what I did with the wheel and it seemed to work. I stole the process from a professional powder coating company.
Unfortunately I've been so busy, I haven't gotten a chance to do the other 4. Autocross last weekend (first place E-Mod. ) , off to visit the parents this weekend.
DrBoost
DrBoost PowerDork
11/1/13 9:06 p.m.
I'm hoping to pick up my oven tomorrow. The only issue is yet another CL flake seller. I have a few others lined up, but this one is a double oven so I'd like to get it. Either way, I plan on buying an oven tomorrow.
aussiesmg
aussiesmg MegaDork
11/2/13 8:09 p.m.
Stupid bare metal pic didn't come out but here is before and after cooking them, don't mind the kid in the photo
Toyman01
11/2/13 8:37 p.m.
Nice!!!
DrBoost
DrBoost PowerDork
11/2/13 8:40 p.m.
Very sweet!!! Am i the only one that finds this addictive?
BTW, i did get the double oven!!!
logdog
logdog GRM+ Memberand Dork
11/2/13 8:43 p.m.
Double oven? Pot pies and powder coating at the same tine?
aussiesmg
aussiesmg MegaDork
11/2/13 8:55 p.m.
DrBoost wrote: Very sweet!!! Am i the only one that finds this addictive? BTW, i did get the double oven!!!
Not addicted yet, but I do have 12 wheels to do yet, and a few underhood challenge parts, then a couple of brackets, I want to test some different textures and .... um I may have a problem
DrBoost
DrBoost PowerDork
11/3/13 5:12 p.m.
Yeah, you have a problem. Naturally I knew that with all the utes you post, but this could redeem your soul.
Keep posting pics of your projects.
chandlerGTi
chandlerGTi SuperDork
11/3/13 7:54 p.m.
http://www.columbiacoatings.com
This is who I've been buying from; I don't do it but I buy and have it done.
py9zpM4v7sHGcLFJZSp3fDBCovovWiFUprEbyhZEOQWXEA9f2hvxmvtgMaPvPwfq
