Jumper K. Balls
Jumper K. Balls UltraDork
1/17/15 6:20 p.m.
I am rebuilding the shifter on Ransoms E28. I placed an order for all the necessary bits and got to work. All seemed well until I realized the selector rod was really worn on the rod joint side which is a metal to metal joint. I opted to just repair it.
Rod with 10mm donor stock
bolt head turned down, shortened and groove cut for retainer
old pin cut off, new one welded on. I went ahead and zinc plated it too!
All new bushings and wear items ready to go. Now I just need to install it. Someone was using the lift today so that will have to wait til tomorrow.
1/17/15 8:00 p.m.
ok.. I am way beyond impressed on your abilities
mndsm
mndsm MegaDork
1/17/15 11:03 p.m.
mad_machine wrote: ok.. I am way beyond impressed on your abilities
I know, right? Freaking grade 8 bolt turned into a BMW shifter for lulz. I'm flabbergasted.
dean1484
dean1484 GRM+ Memberand UltimaDork
1/18/15 12:08 a.m.
Done the same to fix the similar condition on 944 shifters except instead of the c clip I use two thin nuts to lock against each other and a spring washer to keep tension on things.
link to my page. Did this back in 08 and it is still good as new
http://www.ehadesign.com/~dsmith/shift-fix.htm
turboswede
turboswede GRM+ Memberand UltimaDork
1/18/15 1:20 a.m.
In reply to dean1484:
I added 10mm thrust bearings to mine to take the load off the shaft so that the wear won't happen again. $5 on Amazon and happy happy shifting.
Feedyurhed
Feedyurhed SuperDork
1/18/15 5:21 a.m.
Nice work!
TeamEvil
TeamEvil HalfDork
1/18/15 10:03 a.m.
I bought a replacement for my Mustang.
Actually typed the order into Amazon myself.
MAN are my fingers tired ! ! ! ! Gotta take a break from all of this work . . .
kanaric
kanaric Dork
1/18/15 11:17 a.m.
Ya I wish I knew someone like you near me, lol
Toyman01
1/18/15 2:10 p.m.
Nicely done!
novaderrik
novaderrik PowerDork
1/18/15 2:18 p.m.
i would have just removed the old stud, drilled a hole, welded a bolt in place, and double nutted it in place.
but i guess your way works, too..
Uncoiled
Uncoiled Reader
1/18/15 4:28 p.m.
Thats purdy.
N Sperlo
N Sperlo MegaDork
1/18/15 5:46 p.m.
Waiting is for suckers.
gearheadE30
gearheadE30 Reader
1/19/15 7:36 a.m.
How do you DIY zinc plating??
Jumper K. Balls
1/19/15 9:56 a.m.
gearheadE30 wrote: How do you DIY zinc plating??
With this
http://www.caswellplating.com/electroplating-anodizing/zinc-plating-kits.html
dean1484
1/19/15 2:40 p.m.
I don't.. . . I apply some grease (I use the stuff for CV joints in this application) and it never rusts. In my case if it starts to rust I have MUCH bigger issues.
dean1484
1/19/15 2:42 p.m.
TeamEvil wrote: I bought a replacement for my Mustang. Actually typed the order into Amazon myself. MAN are my fingers tired ! ! ! ! Gotta take a break from all of this work . . .
  1. have you priced out a Porsche shifter?
  2. Mine has been customized to accept a Dino shift knob that is shorter than stock. If you look close in the photos on my page you will see a large grade 8 bolt welded where the standard flat stamped metal should be.
So in my case it would have been more work and cost a lot more to get a new shifter. I think it was all of $1.00 in parts that I had lying around anyway and about 15 min of my time.
fidelity101
fidelity101 SuperDork
1/19/15 4:19 p.m.
I welded FC rx7 threads onto my rx8 shifter so I could use my wood shift knob with the new trans but mine looks nothing fancy like that..
QEwDuYPnkHNsXRbL90qcTeNf6f78XuuC5RM3AL8rRVWLUDxHso0BuJDTI6WLRLdY
