Bench Racer (BowtieBandit)
Bench Racer (BowtieBandit) New Reader
1/8/11 3:07 p.m.
When bending brake lines, make sure that your fittings are at the ends when you start... Gave myself a high-five over that one.
914Driver SuperDork
1/8/11 3:09 p.m.
Should have asked.
I'm so good at this stuff 'cause I usually do it more than once.
AquaHusky
AquaHusky New Reader
1/8/11 3:19 p.m.
Now I don't feel so alone.
I am guilty of this same exact thing. Bad part about this is that it was for a friend's car. I got into a convo and just not watching what I was doing.
Nitroracer
Nitroracer SuperDork
1/8/11 3:30 p.m.
Practice makes perfect. And having quality tools to do the job helps too (I don't).
Junkyard_Dog
Junkyard_Dog Dork
1/8/11 3:36 p.m.
Nitroracer wrote: Practice makes perfect.
Maybe thats why I did it twice in a row once Had to drive to a second parts store to get more line.
Ian F
Ian F Dork
1/8/11 3:36 p.m.
BTDT... isn't experience such a wonderful teacher?
If you're lucky, you'll only do it once...
eastsidemav
eastsidemav Reader
1/8/11 3:45 p.m.
Somehow, I just lucked into thinking about it the first time. Used painter's tape to hold the fittings near where they should be.
Now, the reason I needed to be bending new lines...
jimbob_racing
jimbob_racing HalfDork
1/8/11 3:55 p.m.
I did that too once. Now I tape them to the end of the line with some blue painters tape before I start to bend them. That assures the fitting is in the right place when I'm done.
DrBoost
DrBoost SuperDork
1/8/11 4:54 p.m.
Been there, not done that
ArthurDent
ArthurDent Reader
1/8/11 5:17 p.m.
Or make a beauty of a flare ... and then realize you forgot to put the fitting on first!
aussiesmg
aussiesmg SuperDork
1/8/11 5:24 p.m.
guilty, guilty and guilty dammit
wlkelley3
wlkelley3 Dork
1/8/11 6:08 p.m.
^^Yeah me too^^ Especially the flaring and forgetting the fitting. I've even put the fitting on backwards once. Yeah, you only do that once.
Jensenman
Jensenman SuperDork
1/8/11 6:18 p.m.
BTDT as well. Worst one I have done in a while was when bending new fuel lines for the KA24/Dime swap: I bent the new fuel line exactly mirror image of the old one through just plain stupidity. That was a quiet ride to the parts store.
foxtrapper
foxtrapper SuperDork
1/8/11 6:52 p.m.
And place the shrink wrap on the wire before crimping.
I could cut my wire crimp purchases in half if I could ever master remembering this.
griffin729
griffin729 HalfDork
1/8/11 7:04 p.m.
ArthurDent wrote: Or make a beauty of a flare ... and then realize you forgot to put the fitting on first!
And mine was such a pretty flare too. Also have forgotten the shrink tubing before both soldering or crimping.
RealMiniDriver
RealMiniDriver Dork
1/8/11 8:31 p.m.
Guilty on both shrink tubing and fittings.
ansonivan
ansonivan HalfDork
1/8/11 8:48 p.m.
I have never done all of these things repeatedly, that would be preposterous.
internetautomart
internetautomart SuperDork
1/8/11 8:52 p.m.
been there, done that too.
dean1484
dean1484 GRM+ Memberand Dork
1/9/11 7:55 a.m.
Guilty of all the above
Then there is the drain plug in the oil pan.. . ..
DM5fie8oFSyYtOJlzCP8uemM4qwO3EkvA52Z8lUyVgk9qHPZ6Kx6vFD75LwSY67M
