A few months ago I posted about my 2001 Dodge ram 1500 4X4 5.9L after it stalled an wouldn’t restart. The battery was dead after running at night in the rain with blower on full. I finally figured out that the alternator couldn’t keep up under high load and replacing the alternator seems to have fixed it.
After that it still stalled but it cranked fine on the restart. The truck also has a bucking problem from 3/4 full to 1/4 full. the bucking is like the engine shuts off for a full revolutions then try to make up for the down time. The weird thing is the truck never stalls or buck on the trip home, only on the way out. I attributed it it to home being mostly down hill.
I decided that the stalling and bucking had to be nonburnable goop left over from the mating of ethanol and water. I drained the tank completely. I tried burning the gas I took out in my old Gravely tractor which once warmed up will run on kerosine. The tractor had no power and kept stalling until I drained it out. Problem solved I thought.
I refuel it with Sunoco E10 because I had $1.50 off a gallon. The truck ran great for 2 trips with no bucking or stalling. I decided it was fixed so we went on a long drive to get some scrap metal. Out on the interstate the truck started bucking again. I decided to check later for a vacuum leak because it has a MAP sensor and the combination can cause surging.
I went up a large hill on the interstate at 70MPH, I was surprise that on cruise it dropped to 65 and the truck was empty. Going down the other side it stalled, in a one lane construction zone of course. I couldn’t restart because the neutral safety switch is being stupid again and only works in park. I coasted through the zone, pulled over, and it restarted immediacy. I continued on and it stalled 3 more times until I could get off an exit. The third time I restarted the low gas warning light came on ( I started the trip on 1/2) I stopped at the exit, saw no leaking fuel, and decided someone must have siphoned the gas and the fuel gauge stuck at 1/2 and it was stalling because it was empty.
At the exit is a gas station so I put in 10 gallons. I decided to put in E0 as it is one of the few stations that have it at I thought it was empty. The truck started right up, but the fuel gauge went to full. It wasn’t empty after all. The truck stalled trying to get out of the gas station.
On the trip home, I went back on the interstate and the truck ran perfectly. I got off, to avoid some one lane construction. I got back on and the trip was still uneventful. This trip was mostly uphill. I took it out today and it ran perfectly, no problems at all.
Could this be a fuel problem, I always fill the truck up with Sunoco because I can use $off from shopping at Price Chopper. I only fill up every 2 month or so. It still has 10 Gallons of E10 so the E0 I put in only drops it to 5%. I was just wondering if anyone else say something like this or maybe my truck is just possessed.
TLDR: 2001 Dodge truck stalled and bucked, maybe bad gas. E0 fixed it for now.
