1 ... 5 6 7
Slippery
Slippery GRM+ Memberand Dork
7/9/16 4:59 p.m.
Slippery wrote: If it was me, I would remove the oil pan and check the rod bearings, maybe a main to check them. I know you say that the noise came from the top, but if all the lifter "pills" are in place I would move elsewhere unless the problem is obvious. I hope it wasn't a loud exhaust leak.
I dont want to say I told you so but ... I told you so
At least now you know what needs to be fixed.
dean1484
7/9/16 10:17 p.m.
So the real question is why it did that. Any signs of bluing of the rods or other mains?
7/10/16 5:38 p.m.
Didn't notice any discoloration, the rod cap on #3 still looked good, but I heard it was loose on the crank even when the rod bolts were still tight so it will probably have to be replaced.
1 ... 5 6 7
DCX3shywxo7WvTy41jMp6Gk5Gw4yDuwZx3AyRDI4CNu8kOCP4M2qFa4K4dS6k7PG
