nderwater
nderwater Dork
5/18/11 8:26 a.m.
The big news today is that the Camaro's V6 has been revised for more power and lower weight by integrating the exhaust headers into the heads, eliminating the need for 'a pair of old-school iron manifolds, 12 bolts, a pair of gasket and heat shields with six more bolts.'
When I look at the new heads I don't see weight savings, I see a terrific opportunity to easily add twin turbos to this V6 because the exhaust collector is already built right into the head. How big of a risk is there in mounting a hot turbo directly to an aluminum head?
alfadriver
alfadriver SuperDork
5/18/11 8:30 a.m.
Honda already does that.
Aluminum is a lot lighter than cast iron.
And, yes, turbo installation is a lot easier.
(what's incredibly hard is heat rejection....)
stuart in mn
stuart in mn SuperDork
5/18/11 8:33 a.m.
I suppose the aftermarket header manufacturers aren't too excited about this development.
Conquest351
Conquest351 Reader
5/18/11 8:47 a.m.
You can always make a spacer/adaptor for the turbo...
carguy123
carguy123 SuperDork
5/18/11 9:14 a.m.
stuart in mn wrote: I suppose the aftermarket header manufacturers aren't too excited about this development.
Ahh, but the head porters are looking at the money to be made there.
RossD
RossD SuperDork
5/18/11 9:24 a.m.
Before and after power/torque levels? Does it do anything to the power band?
egnorant
egnorant Dork
5/18/11 10:31 a.m.
Its just metal! We used to carve up the integrated intakes on our 200 c.i. Ford 6 cylinders to add carbs.
AngryCorvair
AngryCorvair GRM+ Memberand SuperDork
5/18/11 11:20 a.m.
egnorant wrote: Its just metal! We used to carve up the integrated intakes on our Corvairs to add Weber IDA-3C's.
added some awesome for you.
nderwater
nderwater Dork
5/18/11 12:08 p.m.
Ross - the new motor makes 11 more HP and highway MPG is up from 29 to 30. http://www.autoblog.com/2011/05/17/heres-why-the-2012-camaro-v6-makes-11-more-horsepower/
wMcNSz56jrn6vqvKfRswZwLMd8s5kz2NYeFL7R3sHoG6jngY3gVWwS4mWuTgNOEg
