Durty
Durty Reader
12/11/21 4:43 p.m.
I give you two sides of a crush washer for my BRZ transmission and diff drain plugs.
Is there a proper side to go towards the bolt and towards the trans or diff?
Slippery
Slippery GRM+ Memberand UberDork
12/11/21 5:09 p.m.
I do not know the correct answer, but if it was me I would have the side on the left face the transmission and the one on the right facing the flange of the bolt if that makes sense. So groove against the transmission.
Durty
Durty Reader
12/11/21 9:17 p.m.
In reply to Definitely gone now :
That was my guess.
I also guessed it was most important just to use a new one each time.
aircooled
aircooled MegaDork
12/12/21 1:13 p.m.
I would guess flat side toward the transmission, especially if it is aluminum.  I would rather potentially put a grove into the bolt than the transmission.
I would also suspect, sealing wise, it won't matter.
Durty
Durty Reader
12/12/21 1:47 p.m.
Well I made my choice and went flat side to the nut. I did the same for all 4 bolts so we won't have a head to head comparo.
Pray for mojo
DWNSHFT
DWNSHFT Dork
12/12/21 4:04 p.m.
I don't know.  Never thought about it.
But, thinking about it now, since it doesn't seem obvious, I would put the groove toward the bolt, smooth toward the pan.  If the groove is going to score something, I'd rather replace the bolt than the pan.
But I don't know anything.  :-)
Opti
Opti Dork
12/12/21 9:17 p.m.
There is a TSB for certain years of 2.0 VWs about the drain plug leaking. It boils down to you have to use a crush washer like the one posted or it will leak, and from personal experience they are correct. Im almost positive they spec the grooved side face the pan. It is literally the only car or pan or plug of any sort Ive had this problem on, and have never paid attention to the way they go, and generally prefer copper washers, but since I ran into that If I get one like that I do groove in and havent had any problems.
FxKXfdMo2uX4lD74y2RG6nznztVOtdKfTcicgIgq0xAU5rFkerDEFyKcDDknxsre
