JamesMcD
JamesMcD Reader
11/1/11 11:13 a.m.
I like the idea of the Mighty-Vac for bleeding brakes and such but the one I purchased was total crap. The canister would not hold a vacuum because the lid did not make a seal against the jar, so it was useless for bleeding brakes. Also, after about 20 minutes of attempted use, brake fluid somehow ended up inside the gauge, and shortly thereafter, the pin that joins the pump linkage to the handle fell out and the thing basically fell apart in my hands.
So is there a "professional" version of the Mighty-Vac, perhaps made by another brand, that is not crap? I would like to know.
jrw1621
jrw1621 SuperDork
11/1/11 11:34 a.m.
I have no experience with either of these tools but Griot's is a place that I think of when looking for a better tool or better way.
http://www.griotsgarage.com/product/tools/specialty+tools/one-person+brake+bleeder.do
http://www.griotsgarage.com/product/tools/specialty+tools/reverse+brake+bleeder+kit.do
I do have experience with a Mighty-Vac that will not hold/build pressure.
pres589
pres589 Dork
11/1/11 11:47 a.m.
I bought the metal Mity-Vac and it seemed pretty good until I got gasoline into the thing and over time the internal parts seem to have broken down. I need to rebuild the thing, which is a feature of the metal unit. Not sure if you go the plastic one or the metal one.
They're super handy to have around but if they're a tool that either works great or is trash.
Duke SuperDork
11/1/11 11:56 a.m.
I've got a plastic non-Mightyvac HF special that was about $25 or so, and it's worked great for 3 cars now. Next year we'll see what's left of it when I take it out of the toolchest.
JamesMcD
JamesMcD Reader
11/1/11 11:57 a.m.
By the way, I would pay $100 to a world-champ-at-brake-bleeding GRMer in the St. Louis area who'd like to travel to Mascoutah Illinois and bleed the brakes on my 3rd-gen RX7. I've been working at this for a long time and can't get the system to bleed thoroughly such that there is resistance in the pedal. At one point the system was pretty much entirely empty because I re-plumbed the front half of the car.
Duke SuperDork
11/1/11 11:59 a.m.
What kind of car?
ReverendDexter
ReverendDexter SuperDork
11/1/11 12:16 p.m.
Duke wrote: What kind of car?
JamesMcD wrote: bleed the brakes on my 3rd-gen RX7.
turboswede
turboswede GRM+ Memberand SuperDork
11/1/11 12:20 p.m.
I pressure bleed. Vacuum tends to just pull air around the bleed nipples.
Google how to build a pressure bleeder from a garden sprayer and finally enjoy bleeding and flushing brakes. Cost? About $15, maybe more if you buy the special Motive adapter for the master cylinder reservoir.
jstein77
jstein77 Dork
11/1/11 12:29 p.m.
I have a Mighty-vac that I bought in the late 80's, and it still works great. I just used it on my brakes a few weeks ago.
N Sperlo
N Sperlo SuperDork
11/1/11 12:31 p.m.
It creates a vacuum. Its supposed to suck.
Ian F
Ian F SuperDork
11/1/11 12:38 p.m.
I also have a metal mity-vac, but I've only used it once to bleed brakes and it worked well enough. The canister assembly on mine has broken as well, but you can replace it with a Lisle version from your FLAPS. I mainly use it to prime the new fuel filter on my TDi every 20K miles and don't use the canister.
Dashpot
Dashpot Reader
11/1/11 12:39 p.m.
In reply to turboswede:
When you pressure bleed you're forcing air into the fluid, vacuum bleeding does not do that. Why would you worry about pulling air bubbles into your bleed bottle?
I've been using a (Griots) vacuum bleeder 10-15 times a year for the last 7 seasons without a problem. Just make sure you keep the MC topped off during the process.
turboswede
11/1/11 1:28 p.m.
In reply to Dashpot: because you'll be there all day trying to pull fluid out and just getting air bubbles around the bleeders.
If you follow the proper procedures for pressure bleeding, you'll finish with no air in the system and a topped off reservoir. Why? Because you're not forcing air into the reservoir, you're pushing fluid into it and the end of the line that goes into the reservoir is below the top of the fluid.
Cone_Junky
Cone_Junky HalfDork
11/1/11 1:37 p.m.
At work I use a pressure bleeder that has a diaphragm between the fluid and the air pressure. I find it to be much faster and better at bleeding then my mighty vac.
In fact, at home, I just use a one-man bleed kit made out of a gatorade bottle and vacuum hose before I use the mighty-vac. NEVER have had a problem with my recycled bleed kit.
trucke
trucke New Reader
11/1/11 1:43 p.m.
Once I installed speed bleeders, the whole brake bleeding job became so easy. Here is just one link. These are readily available from different retailers.
http://www.summitracing.com/search/Brand/Russell-Performance/Product-Line/Russell-Speed-Bleeders/?autoview=sku
Ian F
Ian F SuperDork
11/1/11 1:52 p.m.
Cone_Junky wrote: At work I use a pressure bleeder that has a diaphragm between the fluid and the air pressure. I find it to be much faster and better at bleeding then my mighty vac.
The pro-version ain't cheap...
http://www.thetoolwarehouse.net/p-12848-branick-g300.aspx
My experience with speed bleeders has been positive as well, so far... but some have commented they stop working if the thread sealant wears away or don't work well at all if the caliper threads are a tad sloppy.
44Dwarf
44Dwarf Dork
11/1/11 1:52 p.m.
I had a plastic real mighty-vac unit for 15 years when it broke i got the all metal one for HF and it works well but like yours the jar seal sucks only seals 4 out of 5 times... and it only has one port unlike the mighty -vac that had a presure port so you could check things like carb float pop off etc. but i also have home made electric vac pump bleaer and a presure bleeder too
rob_lewis
rob_lewis GRM+ Memberand Dork
11/1/11 1:53 p.m.
Quick hijack on this. Explain to me the need for pressure/vacuum bleeders? I have to replace one of the calipers on my Tahoe and was going to bleed the brakes the old fashion pump, hold, "floor" method.
Is there something about new cars that requires the use of one of these things? Or, is it just the convenience of being able to bleed brakes with one person?
-Rob
Jerry From LA
Jerry From LA HalfDork
11/1/11 1:58 p.m.
I made a blake breeder using fish tank parts. The one-way valves are the same as those used in the "one man" bleed setups for a fraction of the price. Just use some gas line teflon tape on the bleed screws and go to town. If you build four of them, you can do the whole system simultaneously.
Ian F
Ian F SuperDork
11/1/11 1:59 p.m.
Some ABS cars require a pressure bleeder as well as a computer to set the system so the ABS control valve is bled.
That said, I use the 2-person method when I can. Usually faster.
Travis_K
Travis_K SuperDork
11/1/11 2:08 p.m.
With some cars its nearly impossible to bleed the brakes without a pressure bleeder after major disassembley. Most of the time just changing a caliper shouldnt be too big a deal to do it the normal way.
Jerry From LA
11/1/11 2:12 p.m.
JamesMcD wrote: Is there another Mighty-Vac type of product that doesn't suck?
Actually, I think you're looking for another Mity-Vac type unit that does suck. You already own one that doesn't.
friedgreencorrado
friedgreencorrado SuperDork
11/1/11 3:01 p.m.
trucke wrote: Once I installed speed bleeders, the whole brake bleeding job became so easy. Here is just one link. These are readily available from different retailers. http://www.summitracing.com/search/Brand/Russell-Performance/Product-Line/Russell-Speed-Bleeders/?autoview=sku
Where have those things been all my life?
Ian F
Ian F SuperDork
11/1/11 3:08 p.m.
Where have *those* things been all my life?
In the Help! section of your local Pep Boys. About $12/pair the last time I checked.
DrBoost
DrBoost SuperDork
11/1/11 3:16 p.m.
I've had two MV's and they suck, in a bad way. I've used the pro-style pressure bleeders and there is no way a competent tech that knows what is going on is going to put air into the system.
I'll google the DIY garden sprayer, sounds interesting.
8fqnrlCaoBlXfVZySE4g4D7K6NYmDuEGzvgCDKtZDhkptwCqSHlH4vpmWJBsOiNo
