novaderrik
novaderrik PowerDork
12/22/14 12:55 a.m.
my race car is good for 200mph now..
Basil Exposition
Basil Exposition Dork
12/22/14 2:51 a.m.
...just before the explosion and big cloud of steam.
novaderrik
12/22/14 3:02 a.m.
why would there be an explosion and a cloud of steam? it's a Neon, it doesn't make enough power for that to happen..
if it's because of a lack of airflow thru the radiator, i thought of that: she'll be a bottom breather with an airdam that keeps the air from flowing under the car without going thru the radiator first... might even vent the hood..
$200 cars are the best cars to make into race cars..
ebonyandivory
ebonyandivory SuperDork
12/22/14 6:32 a.m.
My F150 would overheat before I even started it with that done to it!
dean1484
dean1484 GRM+ Memberand UltimaDork
12/22/14 7:36 a.m.
Best keep an eye on the temps it was never designed to be a bottom feeder. You will probably want to seal things off in front of the rad to make sure that you are forcing as much air through the rad as possible.
12/22/14 8:16 a.m.
Your bottom breather setup won't be any more efficient than an opening of equivalent size in the tape...TANSTAAFL.
This would work for a landspeed run though, you shut down at the end of the run before the engine overheats.
Merc
Merc Reader
12/22/14 8:36 a.m.
It would also be a good idea to tape off the gaps in the hood, lights and bumper.
AaronBalto
AaronBalto Reader
12/22/14 8:39 a.m.
Merc wrote: It would also be a good idea to tape off the gaps in the hood, lights and bumper.
...and you may as well do the windshield while you are at it.
Merc
Merc Reader
12/22/14 9:30 a.m.
In reply to AaronBalto:
Well, it'd be better to put a piece of plastic there than tape it but I dont think theres racers plastic.
DWNSHFT
DWNSHFT HalfDork
12/22/14 9:43 a.m.
Hmmmm, what's under the car cover?
petegossett
petegossett GRM+ Memberand PowerDork
12/22/14 10:50 a.m.
In reply to Merc:
Coroplast
ross2004
ross2004 Reader
12/22/14 11:00 a.m.
Merc wrote: In reply to AaronBalto: Well, it'd be better to put a piece of plastic there than tape it but I dont think theres racers plastic.
http://www.speedwaymotors.com/Colored-Plastic-Rolls-10-Ft,1557.html
iceracer
iceracer PowerDork
12/22/14 11:10 a.m.
Eh! You can always turn the heater on.
novaderrik
12/23/14 3:53 a.m.
DWNSHFT wrote: Hmmmm, what's under the car cover?
that's just my 84 Buick Regal T Type.. nothing special..
i was just bored and had a roll of duct tape... but i do have experience making cars that weren't meant to be bottom feeders into bottom feeders with the factory grilles totally blocked off: it was worth a couple of miles per gallon on my 74 Monte Carlo and made it feel more stable and planted to the road at speed.. same with my 97 and 98 Cavaliers (worth close to 5mpg) as well as an 87 Celebrity...
as a side note: a roll of garage door weatherstripping is your friend when it comes to sealing headlight and hood gaps..
ZMsdTCgO0XohbNgjuqNMaLYbSKZ8E49f4c5BseCOO8floJCsg9teNaJt7WXXNKll
