Woodyhfd
Woodyhfd GRM+ Memberand HalfDork
7/13/08 9:43 p.m.
I've never used JB Weld before, but as I recall, you can drill and tap this stuff, right?
In an effort to be really thorough in my Honda Mini Trail project: http://grassrootsmotorsports.com/forum/grm/71-honda-ct70-mini-trail-vintage-pit-bike-update/1645/page1/
I managed to strip out two threaded holes in the carb while cleaning it and putting in new o-rings. I'm not sure if its white metal or aluminum. On one of the bad holes, I can just run a longer bolt straight through, but the other is a blind hole. I was going to drill and tap for the next size up, but I'm not sure how much material is there.
Can I use JB Weld for this, or is there another option (besides a new carb)?
oldopelguy
oldopelguy HalfDork
7/13/08 10:03 p.m.
Small stuff like that I usually go with as small a threadsert or helicoil as I can get away with, even smaller than the original size if need be so long as the outside of the insert is as close to the original size as I can get away with. Easy enough to get a new, stronger little bolt (I like titanium myself) and you don't have to change or damage much.
porksboy
porksboy HalfDork
7/13/08 10:07 p.m.
Loc-tite had a product on the market a few years ago that was made for just such occasions. Unfortunatly I cant remember the name of it but you put this goo in the hole and then put a release agent on the bolt and loosly assembled the part, the stuff cures in the hole and you can tighten the bolt and remove it later. Havent seen it in a while tho but Im sure its still out there. Of course the proper way would be a Helicoil....... Or maybe Miata?
Woodyhfd
7/13/08 10:28 p.m.
This is for a tiny, fine thread screw and there's not a lot of metal around it, so I don't think a Helicoil is an option. I'll look for the Loc-tite stuff.
oldopelguy
oldopelguy HalfDork
7/13/08 10:57 p.m.
Check McMaster-Carr for tiny helicoils, all the way down to #2 or 3mm.
One more option might be to replace the blind one at least with a stud if you can. It could be threaded in to any threads still remaining beyond where you stripped them and you could use a quality epoxy or whatever to lock it in place.
I pretty much work on the principle that if it's soft metal and I've stripped it once then it needs inserts or studs so I won't do it again. I always say I'll be easier on it next time, or just more careful, but I really know better.
44Dwarf
44Dwarf New Reader
7/14/08 6:46 a.m.
JB weld does work in carbs. A fellow rare snaped off a Float Ear casting on a $300 racing carb. We JB welded it at the track three years ago. It's still running fine
Helicoils are the best fix of threads.
44
daytonaer
daytonaer New Reader
7/14/08 9:56 a.m.
porksboy wrote: Loc-tite had a product on the market a few years ago that was made for just such occasions. Unfortunatly I cant remember the name of it but you put this goo in the hole and then put a release agent on the bolt and loosly assembled the part, the stuff cures in the hole and you can tighten the bolt and remove it later. Havent seen it in a while tho but Im sure its still out there. Of course the proper way would be a Helicoil....... Or maybe Miata?
Have used the stuff in a non-stressed bolt hole. It did not work, still have some left somewhere. I would not suggest it.
Woodyhfd
7/14/08 7:05 p.m.
I chose to take the non-GRM route and ordered a new carb. Thanks for the suggestions, though.
Nashco
Nashco Dork
7/14/08 7:11 p.m.
For scientific purposes...did you try the JB Weld? Since you've got another carb, no hurt in trying. Heck, it'd be nice to have a spare carb ready to go if it actually works, should you ever have a problem with the new one or find somebody else who needs one.
Bryce
Woodyhfd
7/14/08 7:17 p.m.
I will try some type of repair after the new carb gets here, just out of curiosity. As for hanging on to the old one for a spare; these carbs are notoriously "not worth fooling around with". It takes less than five minutes to swap one completely, though, so I'll give it a try after the fix.
Woodyhfd
7/18/08 8:39 a.m.
Update:
When I swapped the new carb on, I found that the old one had already been helicoiled once. Looks like it was probably time for a new one anyway.
EwxHb6t1I5IpyDFDECiUtwUSOqE5RFTfBIJKXbpQsJR7SvHz38PidLseQIwmnW24
