old_
New Reader
6/11/13 1:28 p.m.
What cars should I be looking at for a cheap high flow fuel pump? Either inline or in tank. I'm losing my storage space and need to move a car (missing gas tank and pump) across town. I'm just going to rig up a sealed 5 gal bucket in the trunk. The car is a twin turbo 300zx. Even though this wont be my permanent fuel setup I wan't something that can keep up in case I need to get into boost.
Thanks!
Mid '80's F150's have external pumps, IIRC. If it's enough for the 5.0, it should be enough for the Z in boost.
BUT... just tow the thing. A bucket of fuel in the trunk is dangerous.
I use later model F-250 V10 pumps. They can flow 80 psi to that beast of a motor's burn rate and are almost a factory fit for E30/E36 car in-tank pumps.
old_
New Reader
6/11/13 2:23 p.m.
Just to rephrase... I'm only moving it like 2 miles in town here. I figure $25 at the u-pull-it is cheaper than renting a truck and trailer. I'll move it late at night when there is minimal traffic. I've got a closed top liquid tight bucket that I'll be using.
old_
New Reader
6/11/13 2:24 p.m.
Think it will over run the stock FPR?
That would just be making the regulator regulate - which it should be doing all the time. Any fuel pump should be driving the FPR to saturation or you would have a low fuel pressure condition.
Mercedes CIS fuel pump made by Bosch. One thing mercedes are good at is burning fuel.
old_
New Reader
6/11/13 3:10 p.m.
What year/model should I be looking for
That is the Bosch 044 I believe. Those are good pumps - also available in BMW, Porsche cars of 90's vintage.
Turbo DSM, MKIV Supra (LOL in a junkyard), Bosch 044 as mentioned.
But seriously, do you have a hundred bucks? A Walbro 255 on ebay AND you get to keep it as a permanent pump.
pres589
SuperDork
6/11/13 4:02 p.m.
2 miles? I think I'd invest in a good tow strap and roll it vs. all the work you'll go through on a temp and possibly dangerous install of a bucket and pump.
Most Mercedes from like 1976 to 1990 used a variant of CIS as did many other manufacturers. Bosch pump with blue band. The fuel pumps are rated pretty high I think over 80psi. Just go to the junkyard these pumps don't fail often.
I think Pres is right about not doing anything foolish to avoid a tow.
Any efi 240/740 Volvo has a nice little package of Bosch pump with fuel filter bolted to the underside of the car. Make sure you grab the wire connector and fuel outlet fitting- inlet is a pretty standard slip on fitting.
I agree on the Bosch pump. A nice little note about them... If you run two of them in parallel, you will have enough fuel flow (even with E85) to take you beyond streetability in most cars. ![](/media/img/icons/smilies/evil-18.png)
