noddaz
noddaz GRM+ Memberand Reader
2/5/12 9:31 p.m.
Is this even possible? Is a LS1/LS2 engine small enough to replace a Northstar engine?
93EXCivic
93EXCivic SuperDork
2/5/12 9:35 p.m.
IIRC the XLR is just a fat Corvette with a Northstar engine.
Keith
2/5/12 9:40 p.m.
I can tell you it would be no problem to replace a Cadillac 429 with an LS engine
They're pretty compact. The Northstar has overhead cams, yes? That grows the engine, which makes it easier to fit an LS engine in there.
AutoXR
AutoXR HalfDork
2/5/12 9:46 p.m.
I have a northstar fiero I built about 10 years ago.. The N* is a huge complicated beast. I would gladly toss for an LS1 if the adapters weren't so hi priced
patgizz
patgizz GRM+ Memberand SuperDork
2/5/12 9:48 p.m.
AutoXR wrote: I have a northstar fiero I built about 10 years ago.. The N* is a huge complicated beast. I would gladly toss for an LS1 if the adapters weren't so hi priced
who needs an adapter when you can get the LS4 from a monte/impala/bonne/gxp
Appleseed SuperDork
2/6/12 12:05 a.m.
Weren't more northstars transverse? Could complicate things.
Knurled
Knurled GRM+ Memberand Dork
2/6/12 7:11 a.m.
noddaz wrote: Is this even possible? Is a LS1/LS2 engine small enough to replace a Northstar engine?
It's mad smaller.
Raze
Raze SuperDork
2/6/12 7:56 a.m.
Yeah a N* is a 90° DOHC V8, it's ridiculously huge (read wide) compared to an LSx. The kicker is that indeed most Northstar powered Caddies (pre latest body STS and XLR) the rest were transverse...
AutoXR
AutoXR HalfDork
2/6/12 10:09 a.m.
In reply to patgizz:
Because Automatic. Making it manual requires oil pan mods (basically fabricate a new one) remounting the starter - etc etc.. The northstar bolted up to the Getrag and required an easy little adapter for the 1 bolt that was out of alignment. The flywheel is aluminum and off the shelf from spec... where as the ones V8 archie uses are a design I am not fond of.
MadScientistMatt
MadScientistMatt SuperDork
2/6/12 11:20 a.m.
Appleseed wrote: Weren't more northstars transverse? Could complicate things.
Transverse LSxs exist too.
Gearheadotaku
Gearheadotaku GRM+ Memberand SuperDork
2/6/12 12:58 p.m.
What kind of Caddy is it going in?
Appleseed SuperDork
2/6/12 2:59 p.m.
We purists try to ignore that fact.
Conquest351
Conquest351 Dork
2/6/12 3:17 p.m.
Doesn't the GM F40 transaxle fit right up to the LS4? Isn't that what most of the Fiero guys are using?
slopecarver
slopecarver New Reader
2/6/12 3:18 p.m.
Unless said setup is in a mid engine RWD configuration as a swap.
IJvlOAp2ND4pDcL9S1HZrqUV8sjEek51f3eN11Abc0vBZc0E1kP48ev13ZnZYv8i
