donalson
donalson PowerDork
4/17/11 6:41 p.m.
Thread from 2011:
so i'm sure this has been discussed before... but... lawn and garden battery in a non daily driven "project" car... any problems with that?... i keep reading conflicting info... so from other GRMer experience... go for it?... shy away? that is the $20 question (literally... $25 for the lawn and garden $45 for the cheapo car battery) thanks guys mark
donalson
donalson SuperDork
4/17/11 6:42 p.m.
er I will ad... no extra electronics in the car/truck... it might get an aftermarket head unit and non stock speakers... but nothing to truly tax the battery.
a401cj
a401cj GRM+ Memberand Reader
4/17/11 7:11 p.m.
why not? what's the worst that can happen?
rustyvw
rustyvw GRM+ Memberand HalfDork
4/17/11 7:14 p.m.
I've seen people do it before. I was going to use one in the Corvair, but my father in law gave me the right battery for free.
Gearheadotaku
Gearheadotaku GRM+ Memberand Dork
4/17/11 7:41 p.m.
12 volts is 12 volts. As long as you have enough amps, I don't see why not.
jhaas
jhaas Reader
4/17/11 7:48 p.m.
ive used a 12v 17ah SLA from a wheel chair in my challenge opel gt. it had a 2.3T in it. it would start it just fine.
super compact, mount in any position and very light weight
donalson
donalson SuperDork
4/17/11 7:59 p.m.
jhaas what did that cost?...
MG_Bryan
MG_Bryan New Reader
4/17/11 8:40 p.m.
I'm currently using a $20 lawn and garden battery in my MGB. It's more than enough to crank it repeatedly. I have a disconnect wired in and it doesn't have any electricals other than lights, gauges and ignition.
SilverFleet
SilverFleet HalfDork
4/17/11 8:40 p.m.
We used one in our red Miata for the $2008-10 Challenges. It worked just fine, you know...for a Challenge car. If it's a vehicle you plan on using more than just that, I would get a real car battery. When the car was driven on the street, it had a regular battery in it.
neckromacr
neckromacr Reader
4/17/11 8:41 p.m.
First time I saw a Miata Battery I said "Thats a lawn and garden battery that's vented!"
Like Gearheadotaku said, 12v is 12v. Its just a matter if it has the cranking amps to do the job. And if it does, no guarantees on how long it'll work.
FlightService
FlightService HalfDork
4/17/11 9:14 p.m.
We ran 2 lawn and garden batterys on our race boat for the 24V system. lasted us a season and still used them in other applications but we would only run them a season.
I don't see a problem as long as you are ok with the fact you won't be able to run a billion amps off of it and it will die sooner.
carguy123
carguy123 SuperDork
4/17/11 9:29 p.m.
jhaas wrote: ive used a 12v 17ah SLA from a wheel chair in my challenge opel gt. it had a 2.3T in it. it would start it just fine. super compact, mount in any position and very light weight
Looks like the Braille battery.
SkinnyG
SkinnyG HalfDork
4/17/11 10:18 p.m.
I ran a lawn and garden battery in my Locost, powering only the basic car including MegaSquirt. I'd get maybe two summers of use out of them before they would die. They don't seem to enjoy the "car" environment (Heat? Vibration? Constant use?). I switched last summer to a Miata battery (wider, but all else the same size) as it had a 5 year warranty instead of the tractor battery's 1 year.
PseudoSport
PseudoSport Reader
4/17/11 11:32 p.m.
SilverFleet wrote: We used one in our red Miata for the $2008-10 Challenges. It worked just fine, you know...for a Challenge car. If it's a vehicle you plan on using more than just that, I would get a real car battery. When the car was driven on the street, it had a regular battery in it.
lol, it never got a real battery. Only time I would take it out was when I had to mow the lawn. I even ran it in the winter when it was 15 degrees out. Cold cranking was not the greatest. My MegaSquirt cold cranking setting were never perfect and the battery would give me 2-3 chances to start the car.
jhaas
jhaas Reader
4/17/11 11:42 p.m.
donalson wrote: jhaas what did that cost?...
$44.65 on amazon. ebay, around $30 flea market, $5.00
racerfink
racerfink HalfDork
4/17/11 11:55 p.m.
I've had one in my street Miata for four years now. Just put the 2nd one in last summer. Most of the guys I run Spec Miata with run them as well. My riding mower takes the same one, but the terminals are reversed.
Pat
Pat Reader
4/18/11 7:10 a.m.
I've had the same one in my Shadow, which was used, for years. I used to daily drive it, it's been raced, sits through winters, etc. Never a problem.
turboHLS30
turboHLS30 New Reader
4/18/11 7:16 a.m.
Why not get a miata or civic battery? They're also pretty small, and they're a regular car battery.
Josh
Josh Dork
4/18/11 8:19 a.m.
I run a lawn tractor battery in my Miata because it was $18, and what appeared to be the same battery with automotive posts was $120. I think the post adapters were $4.
alfadriver
alfadriver SuperDork
4/18/11 8:30 a.m.
In reply to donalson:
Do yourself ONE major favor. Tune the start. So that it's will fire IMMEDIATELY. do that on a regular battery, if you have one.
After that, if you did that well, then the light battery will be ok.
Well, assuming you can even tune the car....
donalson
donalson SuperDork
4/18/11 11:09 a.m.
good point alfa... I do recall that cold start settings are a bit touchy to figure out/deal with.
a normal battery out back would prob be good though with how front heavy the s10 is.
parker
parker New Reader
4/18/11 1:49 p.m.
Ran a lawnmower battery in my Neon for a few years. No problems.
Toyman01
12/13/18 12:24 a.m.
I run cheap lawn mower batteries in the Lemons cars. The Abomination has a Deka Motorcycle battery in it.
SkinnyG
SkinnyG UltraDork
12/13/18 12:48 a.m.
synthia said:
Hey i need to buy a chainsaw sharpener which should be consistent and easy to use i read a post https://topreviewedten.com/best-electric-chainsaw-sharpener/ where i found two best chainsaw sharpener like oregon 511 and timber tuff Bwm. Please suggest me which one to buy.
Whichever one I need to power my canoe.  That one.
SVreX
SVreX MegaDork
12/13/18 5:33 a.m.
Wow. This thread is a revisit to an awful lot of community that is no longer with us. sad
But yeah, Synthia can paddle away in her canoe.
cETfXYBsV0s5iDwEWLHyfQH46nB6jeTjOxKnBZdNfpIZnR18u4CUay5crdhiFj0w
