ignorant
ignorant SuperDork
10/30/08 10:15 a.m.
http://forums.slickdeals.net/showthread.php?t=964631
Given back to the forum is fun (considering all the hell I raised in off topic) yowza...
PDF Linky http://a.slickdeals.net/attachment.php?attachmentid=127707&d=1224358875
Dr. Hess
Dr. Hess SuperDork
10/30/08 11:17 a.m.
It isn't really "leaked" when they hand you the flyer at the store. Got one last week when I bought my trailer for $145.
ignorant
ignorant SuperDork
10/30/08 12:11 p.m.
DOH
Fine..
Here's the Sears one.. that is 100% leaked.. and has tools
http://forums.slickdeals.net/showthread.php?t=978637
Tools & Hardware 3-mil Candle Power Flashlight - $9.99 * 40 Foot Hose Reel - $24.99 4-Pc Tape Measure Set - $4.99 * 76-Pc Screwdriver Set - $9.99 * All Craftsman Garage Storage - 20% Off Black & Decker 17" Electric Hedge Trimmer - $24.99 Companion 7-pc Pliers Set - $9.99 * Craftsman 106-pc Mechanic's Tool Set - $49.99 * Craftsman 10" Compound Miter Saw With AC Laser Trac Cutting Guide - $89.99 Craftsman 10" Digital Level - $29.99 Craftsman 10 Drawer Ball Bearing Tool Storage Combo - $269.99 Craftsman 10" Miter Saw With Folding Stand - $179.99 Craftsman 10" Miter Saw With Stand And Laser Trac Cutting Guide - $119.99 Craftsman 10-pc Air Tool Kit - $49.99 * Craftsman 10 Piece 3/8" Drive Socket Set - $9.99 Craftsman 10" Table Saw With Rapid Retract Stand - $149.99 Craftsman 10" Table Saw With Stand - $89.99 Craftsman 118 Piece Mechanic's Tool Set - $79.99 Craftsman 1.1 HP 17 Gallon Air Compressor - $199.99 Craftsman 11 pc. Standard Socket Accessory Set - $9.99 * Craftsman 12 Amp 7.25" Circular Saw - $39.99 Craftsman 12 Drawer Ball Bearing Tool Storage Combo - $374.98 Craftsman 1/2" Hammer Drill - $69.99 Craftsman 1/2 HP Belt Drive Garage Door Opener - $179.99 Craftsman 12-pc 1/2-in Deep Impact Socket - $44.99 * Craftsman 12 Piece Wrench Set - $19.99 Craftsman 13-pc Spade Bit Set - $9.99 * Craftsman 14 Drawer Chest And Cabinet Homeowner's Storage Combo - $199.98 Craftsman 14 Piece Wrench Set - $39.99 Craftsman 154 Piece Mechanic's Tool Set - $99.99 Craftsman 16-drawer Quiet Glide Storage Combo - $284.98 * Craftsman 16 Drawer Stainless Steel Ball Bearing GRIPLATCH Storage Combo - $899.98 Craftsman 16-gal Wet/dry Vac - 459.99 * Craftsman 1.6 HP 33 Gallon Air Compressor - $299.99 Craftsman 16 Volt Lithium Ion Drill With Light - $99.99 Craftsman 18-Pc 3/8-in Deep Socket Set - $19.99 * Craftsman 1 HP 5 Gallon Compressor With Removal Dolly - $149.99 Craftsman 204 Piece Mechanics Tool Set - $99.99 Craftsman 20-In Wide Plastic Hand Box - $9.99 * Craftsman 2 1/4-ton Floor Jack w/Case - $24.99 * Craftsman 21-pc Speed-Lok Drill/Drive Set - $9.99 * Craftsman 22-pc Bit Set - $9.99 * Craftsman 25Cc Convertible Gas Weedwacker Line Trimmer - $94.99 Craftsman 25Cc Gas Blower/Vac - $89.99 Craftsman 25-ft Locking Tape Measure - $7.49 * Craftsman 260 Piece Mechanic's Tool Set - $169.99 Craftsman 26-pc Screwdriver Set - $24.99 * Craftsman 26" Plastic Handbox - $14.99 Craftsman 2700 PSI Max Pressure Washer - $379.99 Craftsman 2AA Aluminum LED Flashlight - $9.99 Craftsman 2 Drawer Deluxe Mechanic's Cart - $174.99 Craftsman 2 Gallon Wet/Dry Vac - $24.99 Craftsman 2 Piece Tool Bag Set - $9.99 Craftsman 30 LED Rechargeable Worklight - $19.99 Craftsman 32 Piece Standard And Metric Wrench Set - $69.99 Craftsman 348 Piece Mechanic's Tool Set - $349.99 Craftsman 3/4 HP Screw Drive Garage Door Opener - $179.99 Craftsman 35 LED Rechargeable Work Light - $16.99 Craftsman 36Cc 16" Gas Chainsaw - $119.99 Craftsman 3.6 Volt Cordless Screwdriver With Built-In Worklight - $19.99 Craftsman 3/8" Microtork Torque Wrench - $39.99 Craftsman 3-Drawer Portable Chest - $24.99 * Craftsman 3 Drawer Workbench With Backwall - $119.99 Craftsman 3-Gal Compressor - $89.99 * Craftsman 3-Pc Mini Pliers Set - $9.99 * Craftsman 3-pc Pry Bar Set - $19.99 * Craftsman 3 Piece Pliers Set - $19.99 Craftsman 3 Ton Floor Jack - $59.99 Craftsman 3 Ton Floor Jack With 3 Ton Jack Stand And 36" Creeper - $99.99 Craftsman 42-pc Tool Kit - $19.99 * Craftsman 4.5 Amp Jig Saw - $34.99 Craftsman 4 Gallon Pancake Air Compressor - $99.99 Craftsman 4-Pc Adapter Set - $9.99 * Craftsman 4-Pc Extension Bar Set - $9.99 * Craftsman 4-pc Pliers Set - $24.99 * Craftsman 5.0 HP 12 Gallon Wet/Dry Vac - $49.99 Craftsman 540 Piece Mechanic's Tool Set - $999.99 Craftsman 5 Amp Electric Line Trimmer - $29.88 Craftsman 5 Drawer Powered Project Center - $119.99 Craftsman 5-Pc Bolt-Out Add-on Set - $9.99 * Craftsman 5-Pc Bolt-Out Set - $9.99 * Craftsman 5-pc Phillips Screwdriver Set - $4.99 * Craftsman 5-pc Slotted Screwdriver Set - $4.99 * Craftsman 6 Amp Compact Reciprocating Saw - $39.99 Craftsman 6-pc 3/8-in Dive Hex Bit - $14.99 * Craftsman 6-pc Carbide Tipped Router Bit Set - $9.99 * Craftsman 7 1/4in Sliding Compound Miter Saw - $129.99 * Craftsman 7.25" Circular Saw With LaserTrac Cutting Guide And Worklight - $59.99 Craftsman 7.5 Amp Electric Blower - $24.99 Craftsman 7-pc Ratcheting Bolt-Out Set - $9.99 * Craftsman 7-pc Wrench Set w/Free Wrench Roll - $9.99 * Craftsman 7 Piece Locking Flex Ratcheting Wrench Set - $99.99 Craftsman 7 Piece T-Thru Handle Hex Key Set - $17.49 Craftsman 83 Piece Screwdriver Bit Set - $14.99 Craftsman 8 Amp Reciprocating Saw With Bag And 3 Piece Blade Pack - $59.99 Craftsman 8 Piece Ratcheting Wrench Set - $39.99 Craftsman 8 Piece Screwdriver Set - $9.99 Craftsman 9 Drawer Tool Storage Combo - $99.99 Craftsman 9 Piece Large 12 Pt 1/2" Drive Socket Set - $19.99 Craftsman Accutrac Laser Measure Tool - $59.99 * Craftsman Autoloading Multi-bit - $9.99 * Craftsman Barrel Grip Laser Jig Saw - $84.99 Craftsman C3 19.2 Volt 3 Piece Combo Kit - $89.99 Craftsman C3 19.2 Volt 5 Piece Combo Kit - $219.99 Craftsman C3 19.2 Volt Compact Lithium Ion Drill And Driver - $159.99 Craftsman C3 19.2 Volt Cordless Drill With Light - $39.99 Craftsmand 18 Piece Screwdriver Set - $19.99 Craftsman Digital Air Gauge - $12.49 Craftsman Digital Multi-Meter - $14.99 Craftsman Digital Multi-Meter - $9.99 * Craftsman Digital Torpedo Level - $17.49 * Craftsman Easy Fire Stapler - $11.49 * Craftsman Handheld Vac - $14.99 * Craftsman High-performance Ultra Touch Gloves - 40% Off * Craftsman High Power LED Flashlight - $23.99 * Craftsman High-top Work Table - $49.99 * Craftsman Hydraulic Stool - $39.99 * Craftsman Infrared Thermometer - $59.99 Craftsman Laser Trac Level - $8.74 * Craftsman LED Flex Light - $14.99 Craftsman Lock Back Utility Knife With Leather Belt Pouch - $8.99 Craftsman Magnetic Pick-Up Tool w/Light - $7.49 * Craftsman Motorcycle ATV Jack - $89.99 Craftsman NEXTEC 12 Volt Compact Lithium Ion Drill - $79.99 Craftsman Professional 10-in Portable Table Saw - $419.99 * Craftsman Professional 20 Volt 3 Piece Combo Kit - $199.99 Craftsman Professional 3-pc Locking Pliers Set - $19.99 * Craftsman Professional 4 Ton Floor Jack - $119.99 Craftsman Professional Bench Router Table - $59.99 * Craftsman Professional Portable Jobsite Table Saw - $269.99 Craftsman Screw-Out Damaged Screw Remover - $9.99 * Craftsman Speed-Lok 16 Piece Set - $14.99 Craftsman Steel Magnetic Tray - $7.49 * Craftsman Stud Finder - $7.49 * Craftsman Swap Cap Knee Pads - $7.99 * Craftsman Tool Box Cooler - $24.99 Craftsman Tool Center With Riser - $99.99 Craftsman Utility Cart - $59.99 Craftsman Utility Knife Set - $9.99 Diehard Universal Power Adapter - $19.99 * Drill Doctor 350X Sharpener - $49.99 Edsal 5-Shelf Heavy-duty Steel Shelving - $34.99 * Four Piece Barbecue Tool Set - $19.99 GearWrench 18 Piece Ratcheting Wrench Set With Bonus Driver - $29.99 Gladiator 24" Wall GearBox - $79.99 Kenmore 2 Burner Gas Grill With Side Burner - $!29.99 Lisle 12-Pc Torx Bit Set - $16.49 * Magma Cart Folding Hand Cart - $24.99 Mechanic's Gloves - $9.99 * My First Craftsman 71-pc Tool Set - $7.49 * Seven T-Handle Nut Drive Set - $19.99 Six Pack Diamond Plate Interlocking Foam Mat With Border - $9.99 Twin Pack Sawhorse - $9.99 WeatherHandler Glovebox Tool Kit - $8.49 *
SupraWes
SupraWes Dork
10/30/08 4:15 p.m.
I cant wait for the Gainesville HF to open. Going to need a PT job there to pay for it all.
Schmidlap
Schmidlap New Reader
10/30/08 6:12 p.m.
Any idea if the Sears website will have those prices too or is it just in the store? I'd much rather sit at home, buy on the web and pick it up at the store a week later instead of fighting the crowds.
Bob
VanillaSky
VanillaSky New Reader
10/30/08 7:18 p.m.
http://bfads.net/
Much help for navigating.
kreb
kreb GRM+ Memberand Dork
10/31/08 12:19 a.m.
Hmmmf. i went into my first HF a month or so ago. 75 percent of the stuff was low enough quality that I'd be embarased to have it in my shop - and my standards aren't that high.
I walked out with a lovely dead-blow hammer though....
foxtrapper
foxtrapper SuperDork
10/31/08 5:50 a.m.
HF has the coolest stinky rubber hammers. $.99. They smell like burned tar, and just one will make the whole basement reek.
As near as I can tell they figured out a way to condense smoke into solid blackness that resembles rubber.
SupraWes
SupraWes Dork
10/31/08 3:58 p.m.
foxtrapper wrote: HF has the coolest stinky rubber hammers. $.99. They smell like burned tar, and just one will make the whole basement reek. As near as I can tell they figured out a way to condense smoke into solid blackness that resembles rubber.
I'm guessing its old ship decking or something like it that the Indians are melting off and making hammers with, and Dr Hess brand condoms.
zaGwnLVj5vsL9qRSDXroHcW1RZ4QqlN9Icx9xdnV3Gj1Qbwin4LhopaXEJCXSqtd
