RoughandReady
RoughandReady Reader
2/11/14 7:36 p.m.
What's the best way to do this? Have the hubs redrilled?
Flyin Mikey J
Flyin Mikey J Reader
2/11/14 7:48 p.m.
One Q: On what car are we doing this?
RoughandReady
2/11/14 7:50 p.m.
In reply to Flyin Mikey J:
'95 Soobaru Legacy
yamaha
yamaha UltimaDork
2/11/14 7:59 p.m.
As long as the material is there, thickness, distance from existing lugs, etc, you can just redrill the hubs/rotors.
Flyin Mikey J
2/11/14 7:59 p.m.
Having the original holes welded shut and the hubs redrilled has always been a bit dodgy. I've always swapped hubs, whether with OEM from a different year/model or aftermarket. Then again, its always been a GM product (Camaro/Nova/Regal/Chevelle) with Ford rear axle swap that has created my need to do so.
oldopelguy
oldopelguy SuperDork
2/11/14 8:05 p.m.
I'd trust bolt on adapters over welded and redrilled, particularly if hub-centric. Good enough for a 1-ton truck for dually front wheels is good enough for me.
Kenny_McCormic
Kenny_McCormic UberDork
2/11/14 8:10 p.m.
Why would you bother on a car already set up for the extremely popular 5x100?
Curmudgeon
Curmudgeon MegaDork
2/11/14 8:23 p.m.
I had 4x110 RX7 axles redrilled for 4x100, it cost me around $100 and have had zero problems. That's my personal preference, but I have seen billet steel adapters I would trust. They are NOT cheap!
irish44j
irish44j PowerDork
2/11/14 8:23 p.m.
Kenny_McCormic wrote: Why would you bother on a car already set up for the extremely popular 5x100?
this.
Flyin Mikey J
2/11/14 8:34 p.m.
this.
agreed
RoughandReady
2/11/14 9:09 p.m.
Kenny_McCormic
2/11/14 9:12 p.m.
I doubt there is enough meat in the hubs to safely open up the bolt circle a whole 12mm.
Flyin Mikey J
2/11/14 9:13 p.m.
^ good reason as any.
RoughandReady
2/11/14 9:19 p.m.
They were cheap. Rul cheap. Want to fit them on my Subaru for (pretty much) no reason.
Also spotted a set of these at the scrap yard.
RoughandReady
2/11/14 9:27 p.m.
What if I used a 114.3 STI hub? It should have meat.
turboswede
turboswede GRM+ Memberand UltimaDork
2/11/14 9:34 p.m.
I used adapters to fit cheap BMW wheels on my 924. They work great and I can swap back fairly easily.
irish44j
irish44j PowerDork
2/11/14 9:40 p.m.
I would just do the spacer thing, unless the offset won't allow it. Well-made spacers are just as strong as the hub flange, really (especially if you get steel ones). Plenty of them are used on heavy 4x4s doing crazy off-road things, racecars, etc.
moparman76_69
moparman76_69 SuperDork
2/11/14 9:41 p.m.
The best way to do it without using cheap crappy adapters is to buy expensive not crappy adapters.
Kenny_McCormic
2/11/14 9:47 p.m.
In reply to RoughandReady:
That should work, though wobble nuts might work in that case if the hub diameters match.
Leafy
Leafy Reader
2/12/14 8:07 a.m.
RoughandReady wrote: What if I used a 114.3 STI hub? It should have meat.
Different axle spline I believe. You're quickly getting into, "more money than the car is worth" territory. I would see if there's enough meat to re-drill the hubs, there probably isnt. Then I would just sell the wheels for a profit.
turboswede
2/12/14 8:15 a.m.
Don't forget that redrilling the hubs is only half the job. You need to drill the rotors as well and any replacement rotors down the road, etc.
These wheels aren't looking so cheap and easy anymore, are they?
I'd sell them on for what they are actually worth and buy better, lighter and stronger wheels that actually fit your car.
JoeyM
JoeyM GRM+ Memberand Mod Squad
2/12/14 9:03 a.m.
Watching this with interest. I might....er, someone I know might have.....built a car with 5 lug fronts and four lug rears because that's the way the axle came. It sure would be nice to have a spare tire that had better than a 50/50 chance of being useful in the event of a flat.
Leafy
Leafy Reader
2/12/14 9:03 a.m.
JoeyM wrote: Watching this with interest. I might....er, someone I know might have.....built a car with 5 lug fronts and four lug rears because that's the way the axle came. It sure would be nice to have a spare tire that had better than a 50/50 chance of being useful in the event of a flat.
Multi bolt pattern wheel?
turboswede
2/12/14 9:42 a.m.
Staying with the same number of lugs is fairly easy to build adapters for. Going between different numbers of lugs is another matter and usually requires fairly substantial adapters.
I'd look at if there was a way to change one of the patterns with different parts or make new front hubs with a matching lug pattern to the rear and off the shelf rotors. If you list the car you used for the front and rear parts, the collective might help you find the parts you'd need to get around using adapters.
z31maniac
z31maniac UltimaDork
2/12/14 9:48 a.m.
The answer is don't buy cheap, eBay adapters.
But quality ones from a reputable company.
KVUx4lHwY7jvHONBFQhkiiE6YVGmY7cGlKt6oHipCscxJHkBg7wzzI7xnpP2EYC7
