GameboyRMH said:
Keith Tanner said:
GameboyRMH said:
K-Sport is a pretty cheap brand, the same company also sells under the D2 brand. I have plenty of experience with them, they're actually not bad value for the money, you get a proper fully-threaded shock body with independent height adjustment, but you get what you pay for in terms of the damping action. That said I have beaten cars with vastly more expensive struts with them
All you can do with those as-is is turn down the shock rebound with the top adjuster and give yourself some more ride height. You may also be running out of travel *at the top end* with the shock piston acting as a limiting strap, that feels rough and is bad for maintaining traction, you can add tender or helper springs to fix that.
If you want a cushy ride, sell these and go stock. They will never ride nicely.
Argh. There’s a lot of mistaken thinking in that. Maybe not the “cheap two-piece coilovers are crap” part, but the setup. I’m not on a device that’ll let me type much, so I’ll come back to this in a few days.
I'll be waiting, it's perhaps oversimplified, and arguably assumes that something is bottoming out at the current ride height and that the shocks are currently at a hard setting (although note I said "can do" not "should do" ), but I don't see what's *wrong.* On my own D2 coilovers I've had problems with running out of extension travel, this can happen easily when a strut has a single linear-rate spring that is hard for the amount of weight it's supporting. If the spring only compresses an inch under the car's weight, you only have an inch (assuming 1:1 motion ratio) of extension travel, which can easily be taken up on the inside wheel in a corner or if the car bounces over a nasty obstacle.
18kg/mm front/9.8kg/mm rear sound like decent rates for an autocross setup on a car this heavy, and may not be bad on the track, but that's really hard for a street car, especially that front rate.
Sorry, back in front of a keyboard.
"Independent height adjustment" is code for "generic shock cartridge with an adapter screwed on". It's touted as an advantage by the companies that build shocks this way, but it offers decreased overall suspension travel with no benefit. The shorter shock cartridge doesn't allow as much shock travel as a full length shock does, and there's really only one correct setting- short enough to allow full compression. Adjustable preload is another marketing term that's attempting to make a bug into a feature, but it's not really something that has any effect on vehicle dynamics until you get to edge cases where preload approaches the corner weight. A two-piece shock is a downgrade from a properly specified single-piece shock, but it's rare on cheap shocks because it's more expensive to build and takes more careful engineering.
If you are running out of droop travel and topping out the pistons, adding helper/tender springs will have no effect. That's a hard mechanical limit. You've run out of droop travel no matter what you do with springs. Now, if your springs are going loose before you get there, you may want longer springs or helper/tenders.
If this car is bottoming out hard, check to make sure it's not coil bind. It'll feel like metal on metal contact and it leaves characteristic marks on the springs where the coils have come together. The solution is to run longer springs if packaging allows, or to limit compression travel if not.
Note that you can't really assume spring rates without knowing a lot more about the chassis, especially motion ratios.
