Dusterbd13
Dusterbd13 SuperDork
10/13/14 7:32 a.m.
So im up to plumbing on my project. The engine donor used hard plastic vacuum lines with rubber elbows. Id like to do this as well, though I cannot re-use the original stuff due to completely different locations of the stuff it goes to. Primarily the map sensor, egr control solenoid. I can re-use the elbows.
Where do I get the line? How do I form it so it's pretty? Am I asking for trouble? Should I be committed for insanity or stupidity?
ebonyandivory
ebonyandivory SuperDork
10/13/14 7:38 a.m.
I've searched and found both the colored plastic and the color-coded rubber lines. Personally I'd go with the rubber. I'll look into it and see if I can find the companies....
http://www.jegs.com/i/Trans%20Dapt/969/5783/10002/-1?CT=999
http://www.hiperformancestore.com/hosebyfoot.htm
There's also McMaster-Carr
EvanB
EvanB GRM+ Memberand UltimaDork
10/13/14 8:42 a.m.
Nylon tubing and reuse the elbows.
http://www.mcmaster.com/#standard-nylon-tubing/=u4tfvk
Rob_Mopar
Rob_Mopar SuperDork
10/13/14 9:47 a.m.
Would steel brake line work, or are these plastic lines very tiny?
Dusterbd13
10/13/14 10:49 a.m.
Super tiny. Thought about steel, but smallest I've found is 3/16. Might try it anyway. Would the added volume in the line make any difference?
06HHR
06HHR Reader
10/13/14 12:13 p.m.
Dorman sells the nylon hardline under their HELP! brand, Vacuum line. Anybody who has had a 80's - 90's GM product knows about this stuff.
mrwillie
mrwillie Dork
10/13/14 12:20 p.m.
I bought bulk vac line from one of the local parts stores. It was on a spool behind the counter, so you had to ask for it though.
Ditchdigger
Ditchdigger UltraDork
10/13/14 3:11 p.m.
Dusterbd13 wrote: Super tiny. Thought about steel, but smallest I've found is 3/16. Might try it anyway.
try a hobby store that does rc cars/models/planes I have seen 3/32 and 1/8 steel tubing there in 18" lengths
Mitchell
Mitchell UltraDork
10/13/14 11:06 p.m.
Auto parts stores should have them. I managed to break 3 lines earlier this year just by touching them. I went to multiple parts store trying to find the correct inside diameter, but didn't have any luck. Rubber lines in the "close enough" size seem to work just fine.
Dusterbd13
10/14/14 9:02 a.m.
I could go rubber, but the plastic or metal would be more visually appealing. Any idea how to form the nylon stuff?
HyirltEAVSwJk9m0Bm50RzSgEgVUUwHiKjz7FUeBrmE7jkr9A2kX7nOzKEEVdkIn
