Pete Gossett
12/30/19 9:48 a.m.
What would it take to make it run outside of the original car? Is it even possible?
There would be none of the original car’s other systems available for it to communicate with(like the lighting, HVAC, audio, etc. systems). Just engine, trans, and whatever modules & sensors are needed for its operation.
Ranger50
Ranger50 UltimaDork
12/30/19 9:56 a.m.
A prayer. For some reason Ford's can bus is a pita to eliminate. Never mind the direct injection.
Saron81
Saron81 Reader
12/30/19 9:57 a.m.
In reply to Pete Gossett :
You'd need a lot of parts off the donor. You'd need the cluster, steering column, body control module, fuel pump, and driver module, airbag module (controls the fuel pump), the battery junction box, and all the connecting harnesses, including the DLC to start. Even at that point I don't know that it would be happy without the networks.
It may be possible to adapt the 2.0/2.3 Ford Racing control pack to run this motor, but it'd require additional tuning.
It'd be easier (not cheap) to run Syvecs or another standalone that can do DI and VCT.
gumby
gumby GRM+ Memberand HalfDork
12/30/19 10:37 a.m.
An engine is just a fancy air pump. Add fuel and spark at the right time, and it will run.
Ditch all the factory stuff you cannot control, build an intake manifold w/port injection, add a trigger for the ignition, and run a standalone ECU.
alfadriver
alfadriver MegaDork
12/30/19 11:09 a.m.
You are better off starting with a 1.6l PFI engine, and add a turbo than that plan.  And there are thousands of them out there in Fiestas, with manual transmissions.
alfadriver
alfadriver MegaDork
12/30/19 11:11 a.m.
In theory, HP Tuners can do that.  But 1) I'm not sure if it really can, and 2) if it could, I can't help.
But it is listed as one of the supported products.
Pete Gossett
12/30/19 12:10 p.m.
In reply to alfadriver :
Thanks for the input(and everyone else too!). I figured it probably wasn’t worth the effort, or possible within Challenge budget, but it was worth confirming before I passed on it.
Robbie
Robbie GRM+ Memberand MegaDork
12/30/19 12:13 p.m.
So... Do you have a hookup?
Pete Gossett
12/30/19 1:21 p.m.
For a drivetrain? Yes, I have a line on one. PM me & I can give you the details.
Robbie
12/30/19 3:01 p.m.
Done!
kevinatfms
kevinatfms Reader
12/31/19 6:47 a.m.
I always though if i ever wrecked mine id swap it into a Festiva. A 1.6L Fiesta ST powered Festiva would be insane.
Mndsm
Mndsm MegaDork
12/31/19 8:43 a.m.
Is that who's drivetrain I think it is?
Pete Gossett
12/31/19 10:14 a.m.
There’s a $475 Festiva that’s been lingering on Marketplace for months that was my other possible home for this. Unfortunately the lack of a title is pretty much a deal-killer because the resultant car would be too awesome to not get to drive to C&C occasionally.
Tactical Penguin
Tactical Penguin SuperDork
12/31/19 8:15 p.m.
Swapping in a Fiesta ST powerplant was a dream of mine when I had my Mazda 2.  If I had "Berk you" money, I wanted a streetable little track monster that would've been a lot of fun.
9j0uQitOQf7h3KGd9qcsv5ymwiKf98sy19h4HjtVra91apg4gFJ0Odc2qJnW82yO
