carguy123
carguy123 UltimaDork
3/10/19 4:42 p.m.
Let's talk exhaust note tuning.  All the big boys do it, well at least Maclaren does cause I saw the guy at work in a Youtube video.
I recognize that there are basic differences in sound between engines, for instance the sound varies according to the number of cylinders.  To me one of the prettiest sounds on the automotive planet is a BMW V10 M5 when it is on song.  I'm working with a V6 so I recognize I can't get that sound, but can I tune the exhaust note to get something that might give me part of that sound?
I'm also wanting my exhaust to be on the quiet side for around town driving like the M5.  In otherwords, I want it all.
I realize that a lot of getting a pretty exhaust note is subjective and will entail quite a bit of trial and error, but I'd like to minimize the error part some if I can.  I'm also hoping that some of what I learn here can also be applied to my S2000.  I realize it's apples to oranges in sound, but some of the techniques or benefits won't be.
#1 what effect does exhaust material have on the sound?  eg. is Ti inherently higher pitched than regular old, thick steel exhaust tubing?
#2 An X or H pipe helps quieten the exhaust note plus tends to smooth out the sound.  The X is better for power, but if an H is all you can fit would a resonator or glass pack type of muffler within the H help any or affect it at all?
#3 Does header length or material matter much in the overall scheme of things?
#4  Since Hot gases take up more room than cool gases I'm guessing that a properly designed exhaust system would have tail pipe volume diminishing the closer you get to the tail pipe to help keep the gas velocity up to help with scavenging and maintain torque (no you do not need back pressure to maintain torque).
And speaking of exhaust tubing sizes this article about how to build an exhaust system to work Laguna Seca sound limits states that 2 1/2" tubing was the max you could use to get around the noise limits - well along with a number of other things.
http://www.norcal-saac.org/track/doc/soundadvice.html
#5 how much does a turbo affect the sound level, sound quality & sound tone?
#6 How about Anti-Reversion?  From what I can read that's actually a thing.  BUT they say an abrupt change in diameter is needed and yet everything else I read says a gradual change in diameter is better for flow - think more like an expansion chamber of a 2 cycle engine as a comparison.
I know that the further from the tail pipe you put the muffler the smoother the sound and quieter it will be.  That used to be where all mufflers were placed, but the catalytic converters are now mounted there and look at what they have to do to attenuate the sound with those tailpipe mufflers today.
How much do the sound canceling mufflers really affect power over straight through designs?  Many of the larger body type of mufflers use strategically placed and sized pieces of metal to cancel the sound waves.  They also tend to have flow patterns that go all over the place.  I'm guessing the circuitous exhaust route itself is the major disrupter of the sound waves.
I'm building the whole exhaust system from scratch and to a certain degree the chassis around it if I need to so what things do I need to accomodate?
yupididit
yupididit UltraDork
3/10/19 5:05 p.m.
In reply to carguy123 :
In regards to these s85 v10 found in the m5 and m6....I agree
TheRX7Project
TheRX7Project Reader
3/10/19 5:21 p.m.
I can only answer #5 really. Turbos tend to cause a smoother, quieter exhaust note. This can be very clearly noticed when dealing with rotaries and Subaru boxers.
Also on #3, runner length equality does matter for sound. All those Subarus you hear with "that distinct Subaru sound" are running an unequal length header. An equal length header actually smooths the sound out quite a bit (but they do still retain some of that sound). They actually sell headers that are "more unequal" for them, just to get more of the sound (although they do sacrifice a few horses for it).
_
_ Reader
3/10/19 5:48 p.m.
https://www.bosozokustyle.com/2009/10/13/how-to-create-your-own-zokusha-muffler/
this can help you get a higher pitch. Tiny little little capped offshoot pipes get rid of drone and low pitch growl. Make that v8 sound like a flat plane crank.
svxsti
svxsti Reader
3/10/19 6:09 p.m.
I think one of the best sounding V6 engines is the Jaguar XJ220, I wonder what a muffler costs lol.
I've always wondered what a 2.0L S2000 would sound like with with 4 RC51 mufflers off the block. It's all trial and error.
Back when I had my SVX all I needed to do was hollow the cats and the mufflers to sound like a 911 RS to 7k rpm. I actually had people pull up next to me in traffic and ask to hear it again. I also had a JDM 4.44 RA 5 sp swap that kept me rowing and an STi badge on the back so they knew it wasn't an auto.
appliance_racer
appliance_racer Reader
3/10/19 6:23 p.m.
You probably already know this but firing order and cylinder layout/location have quite a bit to do with it as well. Continuing the Subaru example, subaru firing order is 1324 where most inline 4s are 1432. Looking at a subaru from the top would be;
Cyl 3.                  Cyl 4
Cyl 1.                   Cyl 2
If you follow the firing order you can see the Subaru fires one bank then the other so to speak.
On "V" engines the firing order (crank throw) also has a large affect on sound. Think mustang vs Ferrari.
What I'm taking the long way around to saying is, if you are building most of the exhaust system you can manipulate the exhaust sound by how you group cylinders. Search for 180* headers on you tube and you can hear how changing the cylinders that are paired really changes the exhaust sound.
buzzboy
buzzboy HalfDork
3/10/19 7:37 p.m.
Sound is subjective I realize.
In regards to #2 I have always preferred a non-crossed-over dual exhaust. You give up a few horses I believe but to me it's a more raucous and old school sound in the upper RPMs and gives a really mean sounding idle because you hear the individual cylinders firing separately.
Also, similar to what _ linked to, you can look at 1/4 wave resonators to remove unwanted sounds from your exhaust note.
1988RedT2
1988RedT2 UltimaDork
3/10/19 7:40 p.m.
Turbocharger:  The only muffler your engine needs.
carguy123
3/10/19 10:19 p.m.
I wish.
Well does anyone have any input on materials used?
buzzboy
buzzboy HalfDork
3/10/19 10:47 p.m.
I just call it a Rotary Muffler. NCHP doesn't agree with me and requires a real muffler sadly.
bearmtnmartin
3/11/19 1:47 a.m.
I remember reading that triumph tuned the exhaust note of their TR6 by stuffing bits of broom handle up into the muffler. It does have a nice note but I am not up to speed on broom handle science.
kevlarcorolla
kevlarcorolla Dork
3/11/19 11:13 a.m.
In reply to buzzboy :
Agree on the subject bit for sure,next to a harley the worst sounding thing is a "true dual" truck exhaust imho......maybe the idle is ok but everything else is just blatty.
 After headers and full jba exhaust on my truck it sounded great with no drone inside and minimal CIS sound outside.
 That lasted about a month and the drone was terrible in the cab,fabbed up a 34" long branch tube with a capped end and  its like voodoo happened.
Amazing sounding outside and zero drone inside.
3/11/19 12:30 p.m.
For materials, with glasspack mufflers denser packing (and using steel rather than FG) seems to kill high-rev buzziness in I4 engines. Magnaflow uses a good compromise setup with steel near the pipe and FG filling the rest.
edizzle89
edizzle89 SuperDork
3/11/19 12:50 p.m.
maybe just try more turbo's, it can't not work
stanger_missle
stanger_missle GRM+ Memberand SuperDork
3/11/19 1:10 p.m.
My experiences with #2 (hehehe)
An h-pipe gives up a little in absolute flow velocity to an x-pipe but also has a little deeper tone than an x-pipe.
An x-pipe will outflow an h-pipe but makes the exhaust raspier. Maybe a little more exotic sounding than an h-pipe.
I had a DOHC 4.6L with an off-road x-pipe (no cats) and a stainless cat back with single chamber mufflers. It was loud enough to wake the dead. It didn't have a very good tonal qualities (raspy as hell) but it made up for that in sheer, make-your-ears-bleed, assault your sanity volume. It was LOUD. You couldn't have any fun without the cops 3 counties over hearing your shenanigans.
Not my car but an aural doppelganger:
https://youtu.be/yDx895bPeCE
nderwater
nderwater UltimaDork
3/11/19 1:50 p.m.
The Porsche Carrera GT has the most amazing exhaust note. It's a high-pitch wail, like a V10 F1 car or superbike engine at full song.  I'd love to know how they achieved that sound, and why nothing else on the road sounds like that.
3/11/19 1:53 p.m.
The Lexus LFA has a similar sound, the high redline and low rotating + reciprocating mass are the key to getting that kind of sound.
californiamilleghia
californiamilleghia HalfDork
3/11/19 2:14 p.m.
I wonder if they will build an exhaust like tone into EVs ,
A whining electric motor or something like that..,.
Or tires that "sing" in certain conditions.
I t sure will be boring ( and dangerous) if they are completely silent.
84FSP
84FSP SuperDork
3/11/19 3:00 p.m.
Has anyone else noted the difference between stainless steel and aluminized steel?  All else equal it seems that the stainless minimizes the rasp.
I'm doing some research now on a stainless resonated Xpipe cross over as I expect my new headers to stainless H pipe arrangement is going to be a bit louder than desired.  Theoretically I'd still gain a few ponies due to the X pipe and would lose some decibels without HP penalty.
either like this without resonators
or with resonators
Curtis
3/11/19 4:50 p.m.
#1.  Very little.  It has a much greater effect in the frequency ranges at which the tubing resonates, but you'll never get there.  At 5000 rpms, a V6 is pulsing around 250Hz.  Resonance frequencies for metal tubing are likely in the thousands of Hz.  Even in things like brass instruments like trumpets and trombones where they can play near the tubing's resonant frequency, the type of metal used (brass, silver, chrome steel, etc) make minimal timbre changes in the sound of the instrument.  Of course, a trumpet player will describe it as brighter or softer, but to the lay person they all sound the same.
#2.  I usually tell folks to leave Xs and Hs to the manufacturer because they have an R&D budget.  X pipes are less sensitive to placement than H pipes, but both only really have their biggest benefits when properly placed.  Do it for sound, but I don't feel the need to chase down the last 3 hp and 2 torques.  Having said that, I do like the more even sound that a crossover provides.  A similar effect can be accomplished with a 2-1 muffler.
#3. Header length and diameter (to me) are a fixed entity.  The length should be optimized for the maximum scavenging effect and the diameter should be matched to the powerband.  Deviation from that optimal combination could cost power or torque in chasing the sound you want.  Having said that, you can scoot your header dimensions a bit each way without much effect.  Larger diameters will be louder, shorter length will be choppier
#4.   You are correct in your assumption.  Many mufflers have smaller diameter outputs than inputs for this reason.
#5.  Turbos (as a guideline) add 1/3 of a muffler.  That is a highly subjective thing, though.  Do they add 1/3 of a stock muffler, or 1/3 of a race bullet muffler?  Turbos also tend to mix things up.  They combine pulses for a smoother exhaust note.
#6. Airflow hates change.  If you have a nice, laminar flow of a fluid or gas in a tube and change the tube's direction or diameter, it is forced to change and requires a change of energy intensity.  Anti reversion may help on really gnarly engines with a ton of valve overlap, but on a relatively mild engine I don't see the need.  It may assist torque lower in the RPMs, but once you're at WOT and getting to the torque peak, reversion is the least of your worries on a well-tuned exhaust.
Placement of the muffler closer to the tailpipe does make things quieter, but it also greatly helps eliminate interior drone.  When you put the muffler farther forward, there is more length of tubing behind it to re-establish resonance.  This in turn can create standing waves of sound that cause the body panels to vibrate sympathetically.  Back to the trumpet analogy, this is why a trumpet mute goes on the end, not at the player's mouth.  You want to generate the tone you want at the end which gives less opportunity for the resonances to do their own thing.
Some engines will just never sound good and some will never sound bad.  One of the finest exhaust notes (as has been pointed out) is that BMW V10.  One of the worst in the world is the Ford Triton V10.  There are so many hundreds of factors which create the exhaust note, so getting the sound you want would be different for every engine.  Think of the 350/370Z cars with a V6.  They growl like a bobcat and sound incredible.  You could duplicate that entire system on a 3.8L Buick and it would sound like trash.  In the trumpet analogy, it doesn't matter what the qualities of the instrument are if the lips playing it aren't giving the mouthpiece the same type of vibrations.
Cam plays a big role.  Exhaust ramp speed, valve overlap, duration, LSA.  One of the tricks my cam grinder does to make a cam sound "bigger" is to grind a more aggressive EVO ramp to make more of a "pop" of exhaust gas when it opens.  Exhaust port shape is a big one.  Manifold design (equal length, tuned, log) plays a lot.  One of the biggest things, though is firing order.  When you get the exhaust pulses is a pretty important thing in the sound.
OEMs play with big budgets to get it right.  In my garage, I use trial and error.  I make up the system with no tailpipe and then hold a few different mufflers up to it to get an idea.
In general, glasspack style mufflers are not your friend when it comes to power.  There are some that would be fine, but you'll notice that they don't get any larger inside, and usually get smaller.  They don't seem to excel at canceling noise OR flow.  I wouldn't hesitate to use them as a resonator as long as I sized them accordingly.  Race bullets are designed for max flow and the bare minimum of sound canceling.  I do like the idea of the open-chamber mufflers that attempt to cancel sound waves by reflecting them around, but many of them sound pretty raspy to me.  Many of the performance aftermarket offerings use large, adequately-sized passages inside sourrounded by a sound deadening material.  These tend to attenuate higher frequencies better and don't restrict much flow.
Bigger diameter is usually louder.  Longer is usually quieter.
I say, try a bunch and see what you think.
McDesign
McDesign New Reader
1/20/20 10:51 a.m.
Hey, Curtis - just found this thread.  The capped tubes remind me of "quarter-wave" cancellation, used sometimes on Mustangs to take out exhaust drone.  They are sized and positioned to cancel at a fairly narrow frequency range - typically cruising speed.
So - it seems this is what the Bosuki muffler guys are doing - a couple of dead-end pipes to cancel specific frequencies - sort of like a reverse organ.
Would you agree?  I've got 180 degree headers and a custom exhaust I've built on a V8 - can't wait to hear it!
1SlowVW
1SlowVW Reader
1/20/20 11:35 a.m.
In reply to McDesign :
Nothing to ad other than I have seen and heard a similar 180 set up on a hydroplane and it was fantastic.
McDesign
McDesign New Reader
1/20/20 11:38 a.m.
I have had the primary part for a while; but not run it yet with the new tailpipes - in this vid it just had short simple tubes and mufflers - maybe 40" of tailpipe.
Doesn't sound like a V8!
https://www.youtube.com/watch?v=65Jt3K3SU9Y
Forrest
dean1484
1/20/20 12:30 p.m.
Forrest
That is spectacular sounding!!!
NWMpXvWU9sfecYynKOvhLaCWAkG2nd9VgVLa09uLQ6g3BdRlExchX5PYq9iVVFOL
