Dootz
Dootz Reader
10/11/19 3:29 a.m.
The Miata and Civic feel too far common to do up. I'd be looking at something that can compare well with a '94-'97 NA or a '99-'00 Civic hatchback:
  • Needs to have a manual (of course)
  • have an aluminum engine or at least be able to cheaply swap to one
  • Double-wishbones up front at least. Rear doesn't have to be IRS (gotta have rear discs, though)
  • Newer than '95 and able to be found under $3500
  • Would like to have an LSD stock, or at least a cheap option available
Indy-Guy
Indy-Guy PowerDork
10/11/19 6:05 a.m.
Miata with a body swap is the obvious answer here.
(aka a hat car)
Slippery
Slippery GRM+ Memberand UltraDork
10/11/19 6:13 a.m.
Infiniti G20
Not sure about the aftermarket though.
alfadriver
alfadriver MegaDork
10/11/19 6:24 a.m.
+2000 4 cyl Ranger.  Duratec is aluminum, front is double a-arm, I'm pretty sure you can get an lsd for it....
smiley
Otherwise, a second Miata, but to meet your requirements, it has to be an NC or later.
Ranger50
Ranger50 UltimaDork
10/11/19 7:04 a.m.
A arm and ls swapped Mustang?
bmw88rider
bmw88rider GRM+ Memberand UltraDork
10/11/19 7:05 a.m.
Prelude or Integra really are the only others out there outside say a DSM or Neon. Dark horse would be a 2000+ celica but not a huge aftermarket there.
It depends what you consider light weight too. The E36 generation isn't that heavy and has a great following.
KyAllroad (Jeremy)
KyAllroad (Jeremy) UltimaDork
10/11/19 7:33 a.m.
What is your goal with "to do up"?  Autocross, car shows, drifting, track days?  Define light, under 2,200 or under 3,300?
ProDarwin
ProDarwin UltimaDork
10/11/19 7:47 a.m.
Does it also need to be rwd, wagon, v8 and get 40mpg city?
ProDarwin
10/11/19 7:49 a.m.
In all seriousness, you might be able to get into a Z or G35 right at the top of your budget.
fanfoy
fanfoy SuperDork
10/11/19 8:08 a.m.
There are a lot of random requirements, but here is what I can think of:
V6 4th gen Camaro or Firebird.
Any small pick-up.
RX-8
Can I ask why you want the following:
An iron block is not necessarily heavier and can be a good thing if you are considering boost
You are better with a good macpherson strut setup than a bad double-wishbone. For example: E36 vs Ranger
And that single requirement is really removing a lot of great choices
RossD
RossD MegaDork
10/11/19 8:10 a.m.
No Miata? How about a MX-5?
10/11/19 8:17 a.m.
Your wants are going to make this very difficult if not impossible. The only choice I can think of is an older C5 vette that has been put on a strict diet
aw614
aw614 Reader
10/11/19 8:20 a.m.
Slippery said:
Infiniti G20
It has an SR20DE so aftermarket should be somewhat decent Im guessing.
BlueInGreen - Jon
BlueInGreen - Jon SuperDork
10/11/19 8:48 a.m.
An Integra is kind of like a better looking and less common Civic.
The Toyota MR-S was pretty much a direct competitor to the Miata in its day.
BoxheadTim
10/11/19 9:03 a.m.
While I'm all for running a less common vehicle, that clashes with your requirement of good aftermarket support that's close to what the Civic and Miata have. It's either going to be one or the other unless you're looking at other common vehicles like Mustangs etc.
There's a reasonable aftermarket for most enthusiast vehicles, but you have to be willing with less choice, higher parts prices and maybe parts quality that can be a tad off when you're only dealing with a single supplier.
Also, these cars don't tend to be as cheap as a Mivic if they have any sort of following that warrants an aftermarket.
What do you actually intend to do with the car? Looking at it from that perspective is going to be a easier than a list of seemingly random requirements.
sleepyhead the buffalo
10/11/19 9:05 a.m.
Suzuki Cappuccino?
slowbird
slowbird HalfDork
10/11/19 9:24 a.m.
Ford Focus?
  • Needs to have a manual (of course) Check
  • have an aluminum engine or at least be able to cheaply swap to one Duratec 2.3, check
  • Double-wishbones up front at least. Rear doesn't have to be IRS (gotta have rear discs, though) No but it handles good anyway. Rear discs, check
  • Newer than '95 and able to be found under $3500 Check, 05-07 ST with the 2.3 can be had for under 2 grand
  • Would like to have an LSD stock, or at least a cheap option available No but there's expensive ones available
pres589 (djronnebaum)
10/11/19 9:39 a.m.
In reply to sleepyhead the buffalo :
I fear what kind of Cappuccino you could pick up in the USA for $3500.
The requirements are tight.  E36 would be worth suggesting but it doesn't have an SLA front end.  3rd gen Camaro is too old.  C4 Corvette too old for the budget.  Saab 9-3 perhaps?
10/11/19 9:50 a.m.
9-3 has struts in front. Iron block too, I think
Brotus7
Brotus7 HalfDork
10/11/19 9:57 a.m.
Solstice?
10/11/19 10:05 a.m.
Yeah, most of them are over $10k?
Other thoughts:
'03-'11 Traccord and 4cyl 5spd '06-09 Sonata... although, I'm not sure about lsd into the sonata, and it's not really "lightweight", on top of the stigma they carry.
steronz
steronz Reader
10/11/19 10:08 a.m.
04-08 Acura TSX?  Not super light but ticks all the other boxes.
Late 90s Accords/Preludes for that matter, the Prelude might be under 3k pounds.
MadScientistMatt
MadScientistMatt PowerDork
10/11/19 10:33 a.m.
First generation Chrysler cloud car?!?
OK, good luck finding any intact examples, let alone with a manual transmission, although they existed and I can't imagine any stock cloud car selling for over $3500. But they do fit the stated list of requirements, and apparently their use of unequal length control arms was why Chrysler ran them in Super Touring instead of Neons.
ProDarwin
10/11/19 10:34 a.m.
slowbird said:
Ford Focus?
Well, if you are going to omit the DWB/LSD requirement, almost every economy car made after '95 would qualify.
slowbird
slowbird HalfDork
10/11/19 10:44 a.m.
In reply to ProDarwin :
Sure, but the Focus is actually good. And has decent aftermarket.
XEwC9BVBNAQJzXAgZ6jb4WGvgRouclhcRIvwWyz9Bp0QNhQ7HWXW7QYnpa2U2Ct0
