Been thinking of a Locost build influenced by Ak Miller's El Caballo de Hierro from La Carrera Panamericana toned down a bit and mixed with a little early 60's counterculture.
(hotlink for reference)
Donor ideas?
Donor ideas?
I dig the idea. That looks to be a 27 T roadster. Good luck finding steel thats not a fortune, but Speedway is still sort of reasonable on their 27 T 'glass bodies. A '23 T might work also and would be a bit cheaper. You thinking period correct suspension or independent?
Naw, the body will definitely be Locost using as much aluminium as possible. Five link in the rear and A's up front.
Just curious what ideas we'd have for powertrain (flathead 8, early Buick V6), transmission, rear axle and front spindle donors.
Imagine a hot rodder got ahold of a '57 Lotus 7 Series 1 and turned it into a "special".
For flatheads, nailheads, etc the best place to look is the H.A.M.B. classifieds. How about a small block chevy disguised to look like an early Corvette motor?
I know where to get stuff, I'm just curious what ideas we'd have.
and speaking of early Vette motors, how 'bout a Blue Flame with a P-Glide? is there enough room in the footwells for a Powerglide?
phaze1todd wrote: Imagine a hot rodder got ahold of a '57 Lotus 7 Series 1 and turned it into a "special".
I think that is what Dennis Brunton did when he created the Super Stalker
Aeromoto wrote: I've always wondered if any modern engines could be disguised to look like an Offy.
Oldsmobile 2.4 Quad 4 looks somewhat like an Offy from the top with the twin cams. There is some speed equipment for these engines. http://en.wikipedia.org/wiki/GM_Quad-4_engine Probably better engine choices out there for more horsepower in smae size package
How about a BDA cover on a Zetec?
http://www.retro-ford.co.uk/shop/content/bda-zetec-rocker-covers-available-soon
Dr. Hess wrote: You can always pick up someone else's project: http://denver.craigslist.org/cto/2503342619.html
That looks like a steal!
Thank you for being in DENVER! And no, you can't put it in your garage until I get time to fetch it, please don't help.
Ever see a Locost with a 5.0?
How about a Jag 6 cyl out of a late 70s to early 80s XJ-6? Being designed in the late 40s, they have a good look to them when the clutter is removed. I think someone is making a T-5 tranny adapter for them, I forget the specifics though.
Aluminum Slant Six:
Hyperpak
You might have trouble seeing past the carburetor, but ... it woulld be correct for the early 60's.
I just stopped by Don Garlits' Drag Museum in Ocala yesterday while on business. Some of his early dragsters look pretty similar, although they were usuall based on streatched model T frames and meant to go in a straight line. I took a ton of pictures. I'll start a thread with pics of some of the crazier stuff when I get some time.
FYI, the stock flathead made 97hp or close. But modded......
