ErikTheSwede
ErikTheSwede New Reader
11/3/18 6:38 p.m.
Looking for help finding a early compact automatic transaxle to mount a mid engine 2j. Not disclosing the project yet but it has been something I've been thinking about for years and I'm starting to collect parts. End goal is a mid engine 500 hp 2jz. The best option I have found is a Subaru Forrester transmission but the power handling capabilities are questionable. It really needs to be something I can find in a junkyard so I think I may be stuck with the subie trans but if anyone has any other ideas I would love to hear them.
Dr. Hess
Dr. Hess MegaDork
11/3/18 7:11 p.m.
No personal experience here, but there is an Audi and/or VW trans that is the same as a Porsche, if I recall, and it can handle that power level.  Google up GT40 kit cars and look to see what they are using today.
Knurled.
11/3/18 7:23 p.m.
EDIT:  Missed the part where you said "automatic".  Twelve page treatise is now worthless.
I wonder if you could scare up a trans from an early front drive Audi A8.  I *think* those were 5HP24s, not the 5HP19s that most/all over front drive Audis got.
There's always the TH425, if you don't mind a heavy transmission with three speeds.  But you will NOT break it, not with only 500ish HP.  The 425 is a TH400 that is sort of cut and folded in the middle so it outputs forwards, and has a separate iron differential that mounts under the engine.
The Porsche 928's transaxle is also a beefy piece of kit (far stronger, apparently, than the manual trans, which is the opposite of strong) but those are not quite as junkyardable...
FaH6Gt6Ckk7bj05sUQMUy4jdHtBCn5bDcxekk6Y1c503xUBslt0ZSxaGPunYEH2y
