1 2 3 4 5 6
ShawnG
ShawnG UltimaDork
3/21/21 8:42 p.m.
Mickey Thompson used articulated pushrods in his Ford 427 Hemi:
Mr_Asa
Mr_Asa UltraDork
3/21/21 8:48 p.m.
In reply to ShawnG :
That's equal parts amazing and terrifying.
Driven5
Driven5 UltraDork
3/21/21 11:07 p.m.
Would you be able to get a reasonable measure on the max combustion chamber depth, and the general casting thickness of the combustion chamber itself?... Inquiring minds, and whatnot.
Mr_Asa
Mr_Asa UltraDork
3/21/21 11:16 p.m.
In reply to Driven5 :
Probably.  I'm not sure I have those type of calipers hanging out, though.  I'll check what's in my tech drawer.
I did find a decent solid model of an LS head that I can use for design, so I won't need to cut up those end pieces.  If you want to PM me your address I can mail them off to you.
Driven5
Driven5 UltraDork
3/21/21 11:42 p.m.
Message sent.
Also glad to see such good results with the high-temp solder (low-temp braze?) rods. I see you went with the 'recommended' Hobart product. Were they as easy to use as the video made them look?
Mr_Asa
Mr_Asa UltraDork
3/22/21 12:24 a.m.
I don't see the message yet, not even in the Spam folder.  I usually get them just fine.  Strange.  I'll message you in the morning if I don't have it
Technically high temp solder, I believe.  Below the temp for brazing.  Overall I think they were well represented in the video.  A few things weren't really covered in it, but that's just because it was more a comparison vid than a how-to dive.  I put a thread in the Tech Tips section based on my thoughts.
03Panther
03Panther SuperDork
3/22/21 1:26 a.m.
So much fun! Lovin’ it.
I know it’s fun moving fwd. and all, but is it really wise to be fitting parts to a head that isn’t welded yet? I see potential for a problem in the future there?
Ian F (Forum Supporter)
3/22/21 7:35 a.m.
Maybe a crazy thought, but perhaps instead of trying to weld the heads together, plate off the ends of the passages and then use some high-temp o-rings to connect them?
FMB42
FMB42 Reader
3/22/21 7:53 a.m.
Truly amazing fab & mod work. Never a dull moment in here.
Mr_Asa
Mr_Asa UltraDork
3/22/21 11:02 a.m.
Oh, 100% possibility that I'm berkeleying up.  However the solder is as easy to remove as it is to apply, and I could always just cut it again.
Mr_Asa
Mr_Asa UltraDork
3/22/21 11:08 a.m.
I'd be concerned I'd end up with a restriction in coolant flow.
bentwrench
bentwrench SuperDork
3/22/21 11:12 a.m.
That doesn't make it any less ugly!
californiamilleghia
californiamilleghia SuperDork
3/22/21 6:14 p.m.
any easy way to put some dowls between the pieces ?
then they will not be stressing on the weld ,
Mr_Asa
Mr_Asa UltraDork
3/22/21 6:55 p.m.
In reply to californiamilleghia :
Hrm.  Possibly, they'd be fairly small dowels though.  Outside of the combustion chamber areas the widest point in these is about 1/4"
Mr_Asa
Mr_Asa UltraDork
3/23/21 4:24 p.m.
Not every day is filled with awesomeness, sometimes its just the hum drum methodology of making sure you don't look like an shiny happy person when you're done.
Wanted to check the head gasket and see if there were any glaring issues.  I don't think there are, but I don't 100% like it.  The locating dowels are going to need to be worked on at some point, I think.
Took the valves out so I could take the parts to my machine shop and have them clean everything in preparation for welding.  The LS style valve compressor is so much nicer than my truck's, easily took a quarter of the time.
Mr_Asa
Mr_Asa UltraDork
3/23/21 7:27 p.m.
BTW - are the LS intake/exhaust springs and spring retainers interchangeable?  With the compressor they seemed to compress evenly as I squeezed them.
DeadSkunk  (Warren)
DeadSkunk (Warren) UltimaDork
3/23/21 8:34 p.m.
Yes, they're the same parts.
pres589 (djronnebaum)
3/23/21 8:52 p.m.
So what's the plan for that DMZ between the 300 headgasket and the edge of the head where the green bar is currently bolted?  I assume those open volumes normally pass coolant around the ports?
Mr_Asa
Mr_Asa UltraDork
3/23/21 9:17 p.m.
Nope.  There are two areas right on the ends where it looks like on the LS there's some sort of coolant crossover, but for the most part it is open and is the oil drainage area for the valvetrain.  I'm going to have to make some weird lifter cover that meshes the 300 block and LS head, you can sort of guess what it will look like if you look at the pictures in the early part of the thread.
Mr_Asa
Mr_Asa UberDork
4/8/21 12:40 a.m.
Anyone have any idea about what HP numbers engine will pump out if I leave the stock camshaft in with the new head?  A new cam may be a possibility, but right now I'm aiming for as little money into it as possible in preparation for a challenge build.
I'm mainly looking so I can start sizing injectors and other factors so I'm able to start hunting in the junkyard.
I found this for the stock camshaft, and it seems to gel with other pages I've seen
Here's info on flow numbers:
Casting Number 706 and 862
Head: 1999+ 4.8L / 5.3 Liter Truck
Material: Aluminimum
Part Number:
12559862
12561706
Combustion Chamber Volume: 61.15cc
Compression Ratio: 9.5:1
Intake Port Volume: 200cc
Exhaust Port Volume: 70cc
Intake Valve Diameter: 1.89 inches
Exhaust Valve Diameter: 1.55 inches
Stock Head Flow Numbers
Chamber 61.15 cc----0.100--0.200--0.300-- 0.400--0.500---0.550---0.600
Intake 200 cc----------63 ---128----179-----210----218----221-----226
Exhaust 70 cc----------54 -- 93 ----121----145-----163----168----174
What you need to know:
These small combustion chamber truck heads offer no advantage over an LS1 head except the smaller combustion chamber. This along with milling of the deck surface will allow a slightly higher compression ratio to be achieved. Because of the smaller intake valve installed in these heads a valve upgrade is practically mandatory.
A note on the last paragraph.  The stock Ford 4.9L intake valve is 1.60" IIRC, and the max the EFI head can go up to is 1.90" or so, so I'm not that worried about increasing size.
Mr_Asa
Mr_Asa UberDork
4/8/21 1:05 a.m.
Also, a note on roller cams so I don't lose it.  I know the Nelsons were interested in this as well:
lifters
hydralic- 8931-16 (set of 16)
solid- 838-1 or 890c-1 single
linkbars(work with both solid or hydraulic)
836-L
older heads have pill shaped holes for pushrods newer heads do not if you have newer heads then you need rod guides
4839-8 (for 3/8 pushrods) or 4835-8 (for 5/16 pushrods)
timing gears
3224
distributor gear(from comp)
466
when you order your cam you can get/need
roller rockers(1.6 or 1.7 ratio)
rocker studs in (3/8 or 7/16)
beehive springs retainers and locks
pushrods either 3/8 or 5/16 (probably best to wait till assembly to check geometry before ordering)
the bosses for the side cover need to be machined approximately 1/4 inch to accommodate lifter installation the bosses at cylinder 1 and 6 need to be further machined to allow for link bar travel
if installing higher rate springs (recomended to compensate for the accelerated lift) the factory pressed in studs should be replaced with screw in type
https://fordsix.com/threads/roller-cams-for-300-big-six-thread.73706/
Robbie (Forum Supporter)
4/8/21 12:54 p.m.
what are the flow numbers on the stock head? If using stock cam, I'd look at flow gain % at an average lift number and use that  % to go from stock HP to LS head HP.
Very rough but at least gets you in the ballpark for injector size.
Also what is the rocker ratio before and after? 1.6-1.7? You might want to take that into account if the LS uses a different ratio than stock ford (and it's an easy way to make that small cam a bit bigger on a budget).
Mr_Asa
Mr_Asa UberDork
4/8/21 1:46 p.m.
Like the chart below, with an average of 36% intake and 16% exhaust, or different numbers?
Stock, I think is 1.6, but may be 1.5.  Let me dig.  Edit: stock is 1.6
Stock head from here
Casting # E7TE-DC
From an 87 300
Lift------Intake-----Exhaust
.05-------31.8
.10-------58.0-------50.7
.15-------75.6
.20-------95.3-------80.8
.25-------107.1
.30-------119.0------108.3
.35-------131.1
.40-------139.8------123.0
.45-------150.2
.50-------157.9------135.0
.55-------162.1
.60-------166.3------140.7
asphalt_gundam
asphalt_gundam Reader
4/8/21 1:59 p.m.
Hey....those are my flow numbers and Ford 6 thread, hahaha. Long long time ago I did all that.
Mr_Asa
Mr_Asa UberDork
4/8/21 2:13 p.m.
It really is such a small world, isn't it?
Considering your experience with flow numbers, any thoughts?
1 2 3 4 5 6
rXKpMvxxcTO3KZLoisBsOcdAPAtS4MrNDLDatKuCmDi6EIFOvZXEpq72leGl5QBu
