Daylan C
Daylan C UberDork
7/7/19 1:19 p.m.
Found a lead on a decent priced LT1 I might use in my Caprice. Does anyone know if standard gen 1 small block  headers and mounts will work on an LT1? I know the bell housing and clutch is the same as an 86+ Gen 1 but the front accessories are different.
Indy-Guy
Indy-Guy UberDork
7/7/19 1:22 p.m.
In reply to Daylan C :
Headers yes.
Be careful with the flywheel:  Internal versus external balance or something like that.
Daylan C
Daylan C UberDork
7/7/19 1:24 p.m.
In reply to Indy-Guy :
The lt1 still has a t56 bolted to it. I was hoping to run it with the nv3500 already in my wagon and save the t56 for the GTA. I'll definitely look into that flywheel closer before I try it.
Knurled.
7/7/19 1:28 p.m.
Mounts yes.  Headers no.  SBC headers will technically bolt up to an LT1, but the LT1's exhaust ports are about a quarter inch higher on the head relative to the bolt pattern, so using SBC headers will result in sigificant port mismatch.
Daylan C
Daylan C UberDork
7/7/19 1:31 p.m.
Ok so either plan on hunting for LT1 headers or use the stock manifolds that come with the motor.
Knurled.
7/7/19 1:40 p.m.
If it is any consolation, LT1 manifolds are really good, as these things go.  Make sure to use LT1 gaskets.
I like LT1s, but there's so much of them that is similar-but-different that they can be maddening.
Daylan C
Daylan C UberDork
7/7/19 2:00 p.m.
Honestly I was just hoping the headers would work so I could be lazy and not redo the exhaust.
7/7/19 3:12 p.m.
Could you just cut off the flange, and weld the gen 1 headers to an LT1 flange?
Daylan C
Daylan C UberDork
7/7/19 4:16 p.m.
In reply to Appleseed :
Putting some down tubes and a y pipe together is probably less work that trying to cut up a cast manifold and weld primary tubes from a pair of long tubes into the it.
Knurled.
7/7/19 6:05 p.m.
Oh, if you already have manifolds, you probably could grind the ports in the manifolds up.  The iron used in exhaust manifolds may be a bit tough, though.
There used to be a good image online of the port differences.  SBC exhaust ports are mostly centered in the bolt pattern, this is LT1:
Bottom is raised a little, top is raised significantly.
Daylan C
Daylan C UberDork
7/7/19 6:10 p.m.
In reply to Knurled. :
Yeah it's a pair of long tubes that came with the car. I'll take a look and see if a grinder will fix this if I actually get the engine. I told the seller the quickest I can make it to him to pick it up is Friday but it's an unreasonably low price for an LT1/T56 combo so I'm not holding my breath.
Dusterbd13-michael
Dusterbd13-michael MegaDork
7/7/19 6:12 p.m.
Why not just slot the bolt holes in tbe existing headers downward to move the tubes up 1/4 inch relative to the ports? 20 minutes with a die grinder and done. Use sbc and lt1 gaskets to check fit/progress.
At least thats what i would try.
Also, i love an lt1. Such a GOOD sbc.
Probably look at them when the tbi motor in my truck dies.
Dusterbd13-michael
7/7/19 6:13 p.m.
Call in to work with anal glaucoma. They're closing anyway, so why save the pto?
Daylan C
Daylan C UberDork
7/7/19 6:15 p.m.
Solid point if I'm honest.
7/7/19 7:54 p.m.
No, I meant cut the flanges of the SBC headers. Buy or have someone cut steel flanges that fit the LT1 heads. Then weld the SBC pipes on the LT1 flange.
Daylan C
Daylan C UberDork
7/7/19 8:23 p.m.
I'll see. I might even find a set of ok LT1 headers since they did offer the LT1 in later versions of this chassis and they didn't change the platform much.
7/7/19 11:10 p.m.
I remember back in my 9C1 days, headers that fit the LT1 from any of the big companies were non-existant. The ones that did fit were very low volume and extremely expensive.
Daylan C
Daylan C UberDork
7/7/19 11:15 p.m.
Looks like I'm hacking header flanges or building a y pipe then.
NickD PowerDork
7/8/19 8:11 a.m.
I always said that the LT1's biggest weakness was the existence of the LS engine. If the LS engine hadn't come along and replaced it so shortly after it was introduced, I think the LT1 would be a lot higher regarded. It was pretty brilliant in some respects.
Opti
Opti Dork
7/8/19 8:11 a.m.
I'm pretty sure it will work. LT1 manifold were a popular upgrade for sbcs for low clearance applications. It may not be perfect but my understanding was even a square port sbc header will cover the LT1 d port.
The best place to check would thirdgen.org. the chassis originally came with a sbc and many people upgrade to LT1. I think there consensus was it may not be perfect but it works. Id reccomend doing some quick searching over there
Patrick
7/8/19 8:25 a.m.
The budget headers for lt1 b bodies used to be the flowtech 2nd gen camaro afterburners.  It’ll likely seal, you’ll just give up some smooth flow.
If you’re at like $1500 or less it’s too good to pass up.  The transmission is 90% of the value, I couldn’t give away a low mile lt1 a few years back and it got scrapped.
Knurled.
7/8/19 8:46 a.m.
That and the glass wristpins.
And the front dress that was like a Mogwai.  If you got it wet, you got a lot of gremlins.
Opti
Opti Dork
7/8/19 9:23 a.m.
Ehh it's a little overblown, Ive pressure washed every LT1 I've owned or worked on, vented and non vented Opti, it hasn't caused an problems that wouldn't have also happened on a normal distributor equipped vehicle
NickD PowerDork
7/8/19 9:31 a.m.
I imagine if the 2nd-gen had lasted a bit longer than it's 5-year shelf life (and I imagine not too much R&D was going on with it the last year or so as they were working on the LS1) they might have ironed out those issues.
Knurled.
7/8/19 1:06 p.m.
I've had the opposite of that luck.
E65l7cl41HPFK1HWnA7svPGUd3H4QY9qBHxsZgfkZYneqVML1BFbVsTVUY8y2NAP
