oldtin
oldtin HalfDork
7/9/10 10:33 p.m.
A few months ago I was looking into how to make a trigger-controlled clutch. After testing a bunch of concepts (thanks for the suggestions) I ended up with this contraption. Basically an onboard air compressor and accumulator tank. Air cylinder works the clutch master through a bell crank. The electronics get a position signal from the air cylinder that is proportional to the trigger position mounted on the gearshift knob (scavenged an old xbox controller for the trigger and potentiometer) and powers a high speed air valve that opens and closes the air cylinder. So far all the mechanics work and all the electronics work - Just have to finish up and put the two systems together. Added 12 lbs to the car. It wasn't exactly cheap, but it's definitely grassroots. The black box definitely has a matrix/borg kinda thing going on.
2002maniac
2002maniac Reader
7/9/10 11:44 p.m.
very very cool! I want a video of it working!
EvanB
EvanB GRM+ Memberand Dork
7/9/10 11:45 p.m.
Very grassroots indeed, especially scavenging a trigger from a xbox controller
Luke
Luke SuperDork
7/10/10 5:35 a.m.
That is really cool. Is this on the MG? How well does it work (in practice)?
oldtin
oldtin HalfDork
7/10/10 10:00 a.m.
So far I'm still testing but the air cylinder has no problem operating the clutch master and all the electronics send the right voltages at the right time. I just have to track down a ground fault in the mg before the final connection. Should happen today.
dean1484
dean1484 GRM+ Memberand Dork
7/10/10 10:18 a.m.
That is GREAT!!! My MS project put that on the Back burner for me. I am glad to see you carrying on with that!!!
guyZjycMghpEERMX8T4gagPiAVPx8Keg1OZj7zShQQYqxnzsDPVF8Z7Uh2Nj04bQ
