Placemotorsports
Placemotorsports GRM+ Memberand HalfDork
3/11/21 12:06 p.m.
Just noticed on the 4runner that I recently picked up, this small black box plugged in line with the MAF.  Nothing is written on it, anyone have any idea?
spandak
spandak HalfDork
3/11/21 12:08 p.m.
Is it an inline add on? Could you remove it and still put the harness back together? Ill bet its some add on device that alters the MAF signal for more power/more MPG.
Take it out. Probably.
bentwrench
bentwrench SuperDork
3/11/21 12:09 p.m.
That looks like some cheater thing to mess with the MAP signal.
If it was legit it would have part #s on it.
Placemotorsports
3/11/21 12:10 p.m.
It is harness plug that is plugged in between the MAF.  I didn't try to unplug it and hook up the factory harness yet.  May do that this evening
MadScientistMatt
MadScientistMatt UltimaDork
3/11/21 1:11 p.m.
Probably one of the infamous "ebay chip" modules - take a 1 cent resistor, stick it in a 1 dollar potting box, sell it for $75 claiming it will give you 30 more horsepower and 10 more miles to the gallon. These used to be all over the place - now the worthless performance module scammers have moved to sticking an OBD2 connector in a potting box instead.
Placemotorsports
3/11/21 1:27 p.m.
Probably so, I found it odd with no markings though. Would figure they would at least call it the MAFmaster 3000 or something
FMB42
FMB42 New Reader
3/11/21 1:58 p.m.
"If it was legit it would have part #s on it."
Yes it would. Likely a lowest of the low end eB*y so-called 'performance chips' as MSM, etc, say. I could be wrong tho... If you disconnect it make sure that the battery is disconnected before and after for 5-10 minutes (then let it re-learn for 100 miles or so). Keep us posted on your 4runr.
Stubbs
Stubbs New Reader
3/11/21 2:05 p.m.
It's used to stop the ecu from from throwing a cel and/or going into limp mode when the air injection system fails.  Fairly common problem on the 2UZ.
https://rutechsolutions.com/products/aip47?variant=49240265220
Placemotorsports
3/11/21 2:10 p.m.
Stubbs for the win, that is exactly it
WB7n3umkUH5hhpS9c4NUv37XicTdQx6x9IWMtZkXAWnd98WykZcTC1T1VpTRLMxJ
