Tom1200
Tom1200 Dork
10/13/20 10:00 a.m.
We're making up a throttle cable (the old one broke) and I'm looking for a place to buy .085 / 2.15mm cable core.
Anybody have a source?
solfly
solfly Dork
10/13/20 10:44 a.m.
no idea on the size but napa carries some repair cables
Robbie (Forum Supporter)
10/13/20 10:56 a.m.
I have a whole spool of 2mm cable in my garage... I'm betting 2mm is close enough. 2mm cable is also often labeled 5/64ths. your spec is right in between 5/64 and 3/32nds. so 11/128ths? lol
10/13/20 10:58 a.m.
this link was given to me when I was working on similar. Maybe give these guys a call?
http://www.flanderscables.com/
10/13/20 6:27 p.m.
I bought a 30' length of cable from McMaster-Carr to repair a lift control.  It was available in all sorts of sizes.
DWNSHFT
DWNSHFT Dork
10/13/20 6:47 p.m.
I have some applications I would like to make my own cables.  Do you have a good how-to?
Saron81
Saron81 HalfDork
10/13/20 7:18 p.m.
https://acmecarco.com/store/index.php?main_page=advanced_search_result&search_in_description=1&keyword=Throttle+cable+
Here are ones usually used for dune buggies... they're usually cut to fit. They also have a few different ends.
Don49 (Forum Supporter)
Don49 (Forum Supporter) Dork
10/14/20 7:20 a.m.
Bicycle brake cable available at your local Walmart.
pirate
pirate HalfDork
10/14/20 10:44 a.m.
Pegasus Racing did make custom cables with sheaths and various end fittings. I assume they probably have different diameters. Visit their website or give them a call. Very good people to work with.
Scott_H
Scott_H Reader
10/14/20 10:50 a.m.
Most bike cables are 1.5mm.  If you go the fancy bike shop you can get the inner cable teflon coated.  I used one of those for years with no problems.
Curtis73 (Forum Supporter)
10/14/20 1:40 p.m.
McMaster is a good source, as was mentioned.
Rosebrand.com, bmisupply.com, musson.com are all theatrical supply houses with a crapload of wire rope sizes.
Here is what I would do from McMaster
Available in as little as 5' lengths, and only 49 cents a foot.  It's 5/64", so a wee bit smaller than your 0.85" but it shouldn't matter a hill of beans.  You're only pulling, not pushing.  That's only 0.006725" smaller than what you're after.
AuFwkGF2EZyDjAXyGy9GizjPzeBn1d89Ba8EKJsrNVDIOnoL1jppIRUgauqubOGE
