Junkyard_Dog
Junkyard_Dog Dork
1/2/11 4:15 p.m.
My custom wire supplier is on indefinite hiatus and I need at least two sets. Both for turbo Volvos. The last set cost $90 so I'm hoping to buy the supplies, make the sets I need, and use the leftovers to make another set or two to offset the tool purchase. I was thinking of getting a universal V8 set and making just what I need but the "kit' prices at Summit seem a bit higher than I remember. I'm looking for the best/cheapest place to buy the crimping tool(s), bulk wire (8 or 8.5mm), ends/boots, heat sleeves, number markers, etc. Also any advice from those who have done this would be great.
porksboy
porksboy SuperDork
1/2/11 4:53 p.m.
I used to just buy the V8 sets and use a cheap Wallyworld electrical crimper. Course this was 30 years ago when I was sans clue.
daytonaer
daytonaer Reader
1/2/11 4:54 p.m.
I made a set for a custom application (wrong head on wrong block....) From used toyota v6 wires and dodge 2.5 ends (all used). I put a lot of work into them and they worked but still bled enough voltage to shock me if I touched them, so take that for what its worth. I have a custom (some one else-s) handmade set on now, funny enough cost $90....
However I made these with needle nose pliers and used wires. Most cheap wire cutter/stripper/crimper tools have the crimp sizes for smaller plug wires (think 5.5-6mm). They used to sell just the crimp dies for larger performance wires that you could use in a vice, but I could only find them with a "make your own" set, not individually. Quality pliers for crimping plug wires are $30+.
Ebay is a great resource for wire parts. I got an accell 8 cyl universal kit for $30. ie. Click
I think if you get quality crimping pliers you will do well, if you use the cheap-o crimpers (these:)it will be hit or miss. ^bad ^good
Junkyard_Dog
Junkyard_Dog Dork
1/2/11 5:13 p.m.
I've done plenty of repairs using cheap crimpers and parts from spare wires I've saved but want to do it right if I'm going to pay for a roll of wire and all the other parts. I'll check eBay.
Any particular wire type to avoid? I know solid core can cause problems with electronics but what else should I know? Has the magazine done an article on this? If not maybe its time!
Woody
1/2/11 5:17 p.m.
When I worked for a yacht maintenance company, we always made our own from Accel kits. We'd crimp them with regular wire strippers.
Travis_K
Travis_K Dork
1/2/11 5:18 p.m.
Good crimping pliers will cost as much as one set of wires. Taylor, MSD and Magnecor wire seems to be good, but I dont know if they sell it in bulk. Doesnt magnrcor make wires to fit your car? I have liked all the sets I have had, and they make wires for pretty much anything you can get the right kind of ends for.
Zomby woof
Zomby woof Dork
1/2/11 6:46 p.m.
Give Kingsborne a call, and see if they can help you out.
Rad_Capz
Rad_Capz Reader
1/2/11 7:00 p.m.
MSD sells everything separate and/or in bulk to make custom wires. If you're going to make several sets then it's better to buy bulk wire and end pieces. Their univeral kits come with a little crimping tool but their purpose built cutting/crimping tool is awesome if you're going to make more sets of wires over the years.
XCCeBtfnVK3tBTwA73G2jMQZOiCgBsumzjTLS3WijELWgtweYuBsEYfj3l8Rk7x3
