aussiesmg
aussiesmg MegaDork
11/9/14 7:21 p.m.
What is out there?
Not much OEM is going to work so with a fat torque curve from 3000 RPM to 7000 RPM what can take this kind of power?
TheV8Kid
TheV8Kid Reader
11/9/14 7:32 p.m.
In reply to aussiesmg:
For land speed racing we are having to go to g force transmissions. My dad and I took a tour of their facility. It was incredible. So many CNC machines! They can pretty much build what ever you want. Here is a link to what we were looking at.
http://www.gforcetransmissions.com/tran_g101a.asp
Ranger50
Ranger50 PowerDork
11/9/14 7:36 p.m.
G-Force GF-1000 or a clutchless Liberty for a front engine RWD. But then you are easily going to spend 4-5k just for a trans. Although I must say if you start replacing the input and output shafts in a TKO-600, you have a box that should handle that kind of power.
aussiesmg
aussiesmg MegaDork
11/9/14 7:38 p.m.
This is a NA RWD car
Dusterbd13
Dusterbd13 SuperDork
11/9/14 7:42 p.m.
Please tell me that it also makes close to the same torque, and it will primarily be a street car.
1000hp na is a hell of an engine. Must be HUGE.
curtis73
curtis73 GRM+ Memberand UberDork
11/9/14 7:45 p.m.
Torque will kill it before HP. If its a 600 tq engine, you can use several. If we're looking at higher torque, you're pretty limited.
T56 magnum can be built close to what you want, but it may strip out 3rd and 4th... or blow the tailhousing off. Lenco/Jefco might be an option depending on the use of the car.
aussiesmg
aussiesmg MegaDork
11/9/14 7:54 p.m.
800 plus ft lbs, it is one hell of an engine and can be street driven
SBF 432 ci
aussiesmg
aussiesmg MegaDork
11/9/14 7:56 p.m.
TheV8Kid wrote: In reply to aussiesmg: For land speed racing we are having to go to g force transmissions. My dad and I took a tour of their facility. It was incredible. So many CNC machines! They can pretty much build what ever you want. Here is a link to what we were looking at. http://www.gforcetransmissions.com/tran_g101a.asp
I will give them a call, surprised that G Force came up in this thread especially recommended by PACC, they must be working hard on their product development
The_Jed
The_Jed UberDork
11/9/14 8:02 p.m.
Eaton Fuller 10 speed.
Wally
Wally GRM+ Memberand MegaDork
11/9/14 8:10 p.m.
In reply to The_Jed: You'd also get the cool Fast and Furious constantly shifting sound effect.
Swank Force One
Swank Force One MegaDork
11/9/14 8:16 p.m.
Toyota/Getrag V160 or whatever succeeded the T56 are the only oem ones I could think of.
MrChaos
MrChaos GRM+ Memberand Reader
11/9/14 8:36 p.m.
there is a reason most 1000+hp machines are autos, the cost. a stock truck c6 or powerglide is good up to 700ish ft lbs.
bentwrench
bentwrench HalfDork
11/9/14 8:36 p.m.
Borg Warner Super T-10 with the large input shaft?
Worked in a 57 Tbird behind a well tuned BBC with a Mooneyham 12-71 and very Large drag slicks and won trophies....
aussiesmg
aussiesmg MegaDork
11/9/14 8:55 p.m.
I am leaning towards sequential. V8Supercars style
aussiesmg
aussiesmg MegaDork
11/9/14 8:57 p.m.
MrChaos wrote: there is a reason most 1000+hp machines are autos, the cost. a stock truck c6 or powerglide is good up to 700ish ft lbs.
This will NOT happen
wearymicrobe
wearymicrobe SuperDork
11/9/14 9:26 p.m.
What is the budget.
I had a rockcrusher built to hold 800hp and about the same torque years and years ago and it was kind of streetable. Straightish cut gears and a hydro setup and it might be doable. The spider gears and the lugs were the biggest issues, plus tire slippage, not the transmission. Would not be reliable with freeway speeds for any length of time though.
11/9/14 9:47 p.m.
Stop dicking around and get a Lenco. Its streetable if you want it bad enough.
curtis73
11/9/14 10:48 p.m.
There are ways to make a Lenco sorta streetable. Some have reverse and downshift abilities.
Otherwise, you're aftermarket only unless its a super light car with 5:00-or higher (numerically) rear gears. I might try a Magnum T56 (the 6060 upgrade of the T56). Its rated for 700 lb-ft, is super simple to adapt to a Ford, and tons of aftermarket support to make it even stronger.
I'm putting a heavily modified TNET1247 T56 (viper) behind a 550+ tq LS6 and I expect it to last a long time. The magnums should be able to take your HP.
I helped tear down a Magnum that was in a 1000 hp C6 road racer. It went through 6 race seasons before wiping half the teeth off of 2nd gear.
Certainly not overkill by any means, but the Tremec can be made to handle it as long as you don't abuse it. I only mention it because you could have a $2000 transmission that is almost strong enough instead of a $6000 transmission that sucks on the street but lasts forever.
Mr_Clutch42
Mr_Clutch42 Dork
11/9/14 11:01 p.m.
Maybe a beefed up TR6060 can hold that much torque. It's rated to hold 600 ft/lbs .
pimpm3
pimpm3 HalfDork
11/9/14 11:24 p.m.
what about a manual out of one of the newer diesel trucks? Don't some of those make lots of torque srock?
ebonyandivory
ebonyandivory SuperDork
11/10/14 5:18 a.m.
Then, what about the poor rear end?
DeadSkunk
DeadSkunk SuperDork
11/10/14 6:01 a.m.
What about used NASCAR parts? Cup cars run 800 HP these days.
The_Jed
The_Jed UltraDork
11/10/14 6:24 a.m.
ebonyandivory wrote: Then, what about the poor rear end?
aussiesmg
aussiesmg MegaDork
11/10/14 7:33 a.m.
Moser 9 inch with 35 spline axles, all good there
Opti
Opti Reader
11/10/14 8:41 a.m.
The viper spec t56s (don't know what their designation is ) handle that all the time in fbody and viper applications. Normally behind turbo stuff.
tjpFBkbrzbWsGtlSaSO6sH8uQkUAimdqwtH9g5vWot8jv2VyAi2uCB5LRmvloCN2
