plain92
plain92 New Reader
2/5/18 1:44 p.m.
This Mazda F2 2.2 engine looked really good aside from an old crusty head gasket and coolant leaking through 3 & 4 exhaust ports. Refilling the radiator was getting to me and I burned my hand through a leather glove after picking up some free Roxul on CL which was kind of the last straw. 260k on the odometer but I don't know if it's the original engine. Interesting tidbit the forklift version of this engine comes with an aluminum timing cover and chain instead of a timing belt.
Have you seen marks like this before? I can't feel anything and I'm not sure if I can see the other side of the cylinder to check for rust or cracks etc.
Jerry From LA
Jerry From LA SuperDork
2/5/18 3:36 p.m.
The stains were probably caused by coolant interaction with the cast iron block.  I've seen them many times before.  They will not affect your repair.  Meanwhile, you have quite a lot of cross-hatch left and minimal scuffing so spend time to make sure your head/block interface is as good as possible.  Have the head surfaced lightly for a good seal.
einy
einy HalfDork
2/5/18 6:45 p.m.
Can you feel any depression around that area with your fingertip or fingernail?  If not, don’t worry about it.  Crosshatch still looks good as Jerry noted, so probably can’t feel a depression I’m guessing.
Knurled.
2/5/18 7:44 p.m.
Engine must have sat for a while and condensation made a rust stain.
I wouldn't worry about it.  You'd hurt things more trying to hone it out than you'd be hurt by leaving it alone.
njsWX1ZORhH8HbO6lDJ0MuXM835K0LmSsCrITgZl2XQC9F1ePQisLAwA83aWoPsy
