ZOO
ZOO GRM+ Memberand SuperDork
4/13/13 5:02 p.m.
What would be the maximum width rim one could install a 215 width tire on (specifically a 215/45/17)?
I've acquired some gently worn Michelins for DD purposes on my E36 M3. Stock is 225/45/17 and 245/40/17/ This will be strictly for commuting purposes.
I would like to avoid the stretched look . . .
Slippery
Slippery GRM+ Memberand Reader
4/13/13 5:47 p.m.
It is going to look somewhat stretched. I have 205/50s on an 8" front and 8.5" wide rear rim on my e30. I have a little bit more sidewall and it still stretches. Some pics:
[URL=http://s1295.photobucket.com/user/hpdem3/media/e30/IMG_3545-Copy_zpsc4aa678b.jpg.html][/URL]
[URL=http://s1295.photobucket.com/user/hpdem3/media/e30/IMG_2477-Copy_zpsa25f4d8f.jpg.html][/URL]
[URL=http://s1295.photobucket.com/user/hpdem3/media/e30/image1_zps5d38a41c.jpeg.html][/URL]
mndsm
mndsm PowerDork
4/13/13 6:00 p.m.
If you ask the stance tards, they'll tell you a 195 will fit. I've seen a 215 on a 8" and it doesn't look terrible, but that's about as far as i'd go.
iceracer
iceracer UberDork
4/13/13 6:13 p.m.
8" max.
Snrub
Snrub New Reader
4/13/13 6:20 p.m.
Go to tire rack and look up the specs for compatible rim width for your particular tire. If they don't have your make/model you can find something similar. Most of the time tires of a given size have similar width requirements, but sometimes they will differ by a 1/2" or so.
corytate
corytate SuperDork
4/13/13 7:07 p.m.
per what I learned today, you CAN get a 225 on a 9.5" wheel
Anti-stance
Anti-stance UltraDork
4/13/13 7:44 p.m.
mndsm wrote: If you ask the stance tards, they'll tell you a 195 will fit. I've seen a 215 on a 8" and it doesn't look terrible, but that's about as far as i'd go.
I have seen, and mounted smaller than 195 on an 8" wheel. Worse prolapse ever.
Swank Force One
Swank Force One MegaDork
4/13/13 7:49 p.m.
corytate wrote: per what I learned today, you CAN get a 225 on a 9.5" wheel
Not surprising. 225 works best on a 9".
nicksta43
nicksta43 Dork
4/13/13 9:09 p.m.
I'm going to go with 6.5" but I don't like to have my tread width narrower than my wheel width.
GameboyRMH GRM+ Memberand UltimaDork
4/14/13 6:52 a.m.
For no stretch on a 215/45/17 go with 7.5" max.
That's the setup on the front of this car:
You can see it's right between "stretch" and "squeeze."
Same setup again on an FRS:
Swank Force One
4/14/13 7:53 a.m.
I had no idea Enkei did the color scheme of the old RP01 Special Editions on the RPF1.
That's HOT.
Grtechguy
Grtechguy UltimaDork
4/14/13 9:43 a.m.
GameboyRMH wrote:
I was like "Damn.....1.53 for gas?", then noticed it was in liters
wrongwheeldrive
wrongwheeldrive New Reader
4/16/13 2:26 p.m.
I don't have an answer to your question, but I do know that the MINIMUM is 5" ;)
e_pie
e_pie HalfDork
4/16/13 2:31 p.m.
I wouldn't go much wider than 8"
Even that will start to be a stretch if it's a particularly narrow tire.
e_pie
e_pie HalfDork
4/16/13 2:32 p.m.
Lol glad I'm not the only one that thinks a super stretched tire looks like that.
ReverendDexter
ReverendDexter UberDork
4/16/13 6:38 p.m.
Rule of thumb that I use is that a tire should be somewhere between 100% and 125% the width of the wheel, ideally somewhere between 110-120%. Factory sizing on Mustangs, for instance, is right around 120% (225 on a 7" 245 on an 8", 275 on a 9").
So, assuming that the tire is dimensionally accurate, the largest wheel I'd put a 215 on would be an 8.5", though that will certainly have a stretched look to it.
dsg8ZuQszIZoHR0QETteQY4vGRK38g79cxVu63K35eWe2ytM7qgZjImtKaRmXmxI
