SPG123
SPG123 HalfDork
7/2/20 3:11 p.m.
Our beloved 09 Mazda 5 Grand Touring needs engine / trans mounts. There are a lot of inexpensive options online. Any experience there? And four piece kit? Thanks!!!
In reply to SPG123 :
I bought the cheap ones from Amazon for our 06 mazda5. Been just fine.
Only really needed tbe passengers side fluid one, really.
paul_s0
paul_s0 Reader
7/2/20 4:06 p.m.
I've got an Anchor brand mount on the PS, sourced from Rockauto, it's adequate although quality notably less than OE.  If it's not urgent, I used https://partsouq.com/ to get an OE Mazda mount for the driver's side, they are based in the Middle East.  Prices are decent, and shipping reasonable -seem like a good option for OE parts.  Took 2 days to despatch, then 10 days to arrive, that was mid COVID, and here in Peru where things are less than 100% efficient.
If I were to do it again, I'd source all of them from Partsouq.   Parts lookup is a bit clunky, butwith patience you can find right bits.
chandler
chandler PowerDork
7/2/20 8:57 p.m.
I drove mine 206,000 miles and replaced the rear trans mount three times. The one that worked was actually for an electric focus. 100,000 miles on it when I replaced all of them while I was doing the clutch and axles at 205,000.
Tony Sestito
Tony Sestito PowerDork
7/2/20 9:06 p.m.
I'm on my 2nd P/S mount, 3rd rear mount, and I'm about to swap in my 4th trans mount in my 184k mile 2012 3. As far as the trans mount goes, I should have stuck with the factory mount. The last two trans mounts I've done were aftermarket and apparently the incorrect design for my car. I'm assuming the 5 has the same mounts as the 3, but I could be wrong.
xhJeQ21mm1f6QpygvUUyPW98D8xuQ2ni7JhExqxB3aiOaO2QjNX8ZyjgSqjgxXxU
