4/9/21 11:33 a.m.
So, trying to find dimensions of the eccentrics from a miata. See if they will work for my neon. Cant seem to find the original ones anymore.
Anyone have a loose one laying around?
Diameter of the eccentrics,  size of the bolt (m10?), width between the eccentrics.
DeadSkunk  (Warren)
DeadSkunk (Warren) UltimaDork
4/9/21 11:42 a.m.
32mm diameter, bolt is 12mm, 57 mm between the eccentrics
accordionfolder
accordionfolder SuperDork
4/9/21 11:53 a.m.
4/9/21 11:59 a.m.
Damn. Too wide.
Back to the hunt!
DeadSkunk  (Warren)
4/9/21 12:04 p.m.
If you have access to a milling machine you could cut the grooves for the eccentric several more (about 10mm) millimeters before you run out of thread. See Accordionfolder's pictures.
4/9/21 12:11 p.m.
Im looking at 35-36mm beyween the lobes of the eccentrics.
M12 bolt, or m10
31-33mm eccentric diameter.
So the miata bolts are just twice as wide as i can work with. Otherwise perfect.
Unless tgeres a way to thread and mill them significantly more that im not seeing,  or a grm'er with that ability.
5Csp2HyuTzq4XMGnkBjWVmwmmoJbNcaDnolUT9VV7raVEhQaFtbeJL2xV9OUaYyG
