petegossett
petegossett GRM+ Memberand Dork
6/30/09 11:16 a.m.
I recently put a set of EBC Greenstuff pads on the rear of my 96 Miata. Even after removing the 14mm bolt & loosening the Allen screw, I stll couldn't get the right-rear caliper loose enough to slide over the pads with the backing plates on, so I left them off.
I finally had more time to dig into it again & I still can't get it to work. So far I've put a clamp on the caliper piston while I back out the set screw - I feel the screw get loose, but the piston doesn't move. I also tried loosening the MC cap & bleeder screw on that caliper - I got fluid out, but the brake still feels locked solid.
Fwiw - when I ran without the anti-squeal plates, the brakes felt fine. No pull or anything. Is it possible the e-brake cable is too tight, or should I look at buying a caliper
Keith
6/30/09 11:28 a.m.
I've seen a few aftermarket pads that were just a bit thicker than the stock ones, and the pistons simply don't retract far enough to make them fit.
93celicaGT2
93celicaGT2 Dork
6/30/09 11:28 a.m.
I'd say caliper. Be VERY sure that you're putting even pressure across the whole piston, otherwise it'll cant to the side and bind.
That was probably stupid "yeah, i knew that" advice, but i've fallen into that trap myself.
petegossett
6/30/09 11:56 a.m.
Thanks for the replies!
Keith - The driver's side rear pads went in fine. They were thicker & it seemed like I had to back the adjuster all the way out for them to fit, but they did fit & I was able to adjust the pads per the recommendation from your book.
So, would it be the end of the world if I didn't run the anti-squeal plates on the pads? I didn't have any noise when I took it to the autox & back like that.
Keith
6/30/09 12:28 p.m.
Definitely not the end of the world.
GameboyRMH GRM+ Memberand SuperDork
6/30/09 12:54 p.m.
Yep the only problem you might have is...squealing...
7W4JSqosP4kDjqdvoey3AAExYoqmnHcOg928dLKEInqr72aF3qemwWz39mjaKaag
