Swank Force One
Swank Force One MegaDork
3/10/15 8:31 a.m.
I was installing my Wilwood master cylinder last night, and it was a really awful time. I believe that part of it is from trying to use as much OEM stuff as possible.
Questions:
1) If i install one of these, can i get rid of that silly and annoying junction block next to the master cylinder? This master cylinder is dual reservoir, dedicated front, dedicated rear.
2) Dumb question: Is there a guide for installing one of these things? Goes inline on the rear line, right?
stafford1500
stafford1500 GRM+ Memberand Reader
3/10/15 8:59 a.m.
1) don't know... probably. It likely has a shuttle in it that tries to lock out a front or rear leg if one develops a catastrophic failure/leak. 2) yes inline to the rears
Swank Force One
3/10/15 9:31 a.m.
stafford1500 wrote: 1) don't know... probably. It likely has a shuttle in it that tries to lock out a front or rear leg if one develops a catastrophic failure/leak. 2) yes inline to the rears
Well... if it has that shuttle, it didn't work. The driver's rear caliper was leaking horrifically badly.
Thanks for the input!
3/10/15 10:16 a.m.
Our proportioning valve kit deletes that block. Put the prop valve in the rear line, put a union in the fronts.
http://www.flyinmiata.com/support/instructions/suspension/proportioning_valve.pdf
H9hIMfK3NcUUX4quPaYZqvZBIGIm2nTzksbyAtBBAaJ8U0APqFOf5d9NJRx0cEVk
