Carson
Carson Reader
6/3/08 1:00 p.m.
My '91's clutch is showing some strange symptoms. The clutch pedal feels normal, then soft, then dead, then back to normal, then feels like I'm stepping on a bowl of oatmeal, then normal, then I'll go to shift and it's already on the floor.
I recently (about 1 month ago) replaced the leaky slave cylinder and while doing so I also went ahead and replaced the rubber hose with a braided steel.
There are no leaks that I can see and the fluid level has remained at the full mark
My first thought was air in the line, but would it take a month of daily driving for the symptoms to show? Now I'm thinking it is the clutch master cylinder on its way out.
What do you guys think?
mistanfo
mistanfo Dork
6/3/08 1:14 p.m.
Sounds like you're right about the master.
Keith
Keith SuperDork
6/3/08 1:36 p.m.
I'd start by bleeding the system, because I'm lazy and that's less work than replacing anything.
Carson
Carson Reader
6/3/08 5:35 p.m.
Keith wrote: I'd start by bleeding the system, because I'm lazy and that's less work than replacing anything.
Agreed. That's what I am going to do first. Of course the drive home was trouble free with a normal clutch feel the whole way.
Could air cause the erratic behaviour?
dollraves
dollraves New Reader
6/3/08 8:02 p.m.
That's pretty much what my master in the '88 Mazda 323 GTX did when it died.
I say buck up and replace the master cylinder.
NKItSbmQq9INXjiZrjqrdcblZ574whxuOR1IuNckSmxCOLhy2D3rZuWkqT2TXFUx
