DeadSkunk
DeadSkunk PowerDork
7/5/18 10:03 a.m.
The Challenge Miata has developed a drip, right from the area behind the crankshaft pulley. I'm assuming I'm looking at a water pump and timing belt while I'm at it. Unless there's something else that could cause this that I'm unaware of. Confirm/correct my diagnosis, please.
wlkelley3
wlkelley3 UltraDork
7/5/18 11:37 a.m.
That's what it was every time I've seen that. And yes, good idea to replace timing belt while it is off to replace water pump.
Dusterbd13
Dusterbd13 MegaDork
7/5/18 11:54 a.m.
The neck that bolts to the block has a gasket there. Could it be bad?
DeadSkunk
DeadSkunk PowerDork
7/5/18 12:00 p.m.
In reply to Dusterbd13 :
It could be. I'll start dismantling things as if the pump is bad and stop if something else becomes apparent.
mainlandboy
mainlandboy Reader
7/5/18 12:07 p.m.
That was the cause of the coolant leak on my Miata. There's a good chance that is what DeadSkunk will find.
Tyler H
Tyler H GRM+ Memberand UltraDork
7/5/18 2:34 p.m.
Miata is the easiest car I've ever changed the TB on.  I'd do it all if it's due to TB or unknown age/mileage.
Good opportunity to inspect the crank keyway, too.
7/5/18 2:45 p.m.
What Tyler said.
DeadSkunk
DeadSkunk PowerDork
7/5/18 5:19 p.m.
I ordered the parts to do it anyway. I bought the car with 115k on it and have no idea if the timing belt is original or not , so may as well do it all while it's apart.
7/5/18 6:55 p.m.
Even if the timing belt isn't original, it's due at 120k so you're not far off a scheduled change. And a lot of people skip the water pump at 60k.
J04U0E0erBr9ZBCweGd5nsR99L3OWvQkIRSxG8JdGEefCj1CVEZBePsOELnq6Zup
