OldGray320i
OldGray320i Reader
1/30/15 2:18 p.m.
Ok, so driving the car home the other night, you could definitely hear the gear box whirring as it drove along - not a "noise" or "whine", just the whirring of the gear box. Normal?
Second question, are there any gearbox fluids that should NOT be used in a Miata? In the add, the PO mentioned he'd changed the fluids; I know for the old Z-cars, there was a particular type that should not be used as the "metallurgy" was bad for the syncros.
If there is something "not good" for it, I'll be adding a fluid swap to the couple other knick knacks the car needs.
Swank Force One
Swank Force One MegaDork
1/30/15 2:19 p.m.
Yes they have brass syncros. There's bad fluid.
I can hear the transmission in all of mine. Especially 1st gear.
1/30/15 2:48 p.m.
Old Land Rovers need specific fluids or the synchros start to come apart.
As for the Miata, fill it with Redline MTL (street car) or MT-90 (track car) and stop worrying.
OldGray320i
OldGray320i Reader
1/30/15 3:22 p.m.
I do love MTL; thanks fellas.
beans
beans Dork
1/30/15 3:59 p.m.
My '95R made a whining noise in 1-4(4th was LOUD, like almost straight cut loud) after I dropped in a junkyard box from a '92. I swear 2nd gear was shorter, too.
Turns out miata 'boxes don't like powershifting though.
peteyjoe
peteyjoe New Reader
1/30/15 4:29 p.m.
If the shifter gasket/lower boot is torn at all that will also let A LOT of noise in. I was amazed at how much things quieted down (relatively speaking of course) when I swapped in a new one.
kazoospec
kazoospec Dork
1/31/15 8:34 a.m.
The good news is a full shift turret rebuild and fluid change is relatively cheap (seems to me it was well under $100 for the whole thing) and is a great Saturday afternoon project. There's a decent chance your car is due for it. If you are feeling any slop in the shifter, do both.
There's also a trans fluid option from Ford Motorsports that works, which is what I used because I could get it locally. I've read reviews from people who have tried both, and the consensus seems to be the Redline fluid is better.
Swank Force One
1/31/15 8:47 a.m.
Fluid preference depends on which forum you ask.
xG91Chs3nbhJoCy6Iw3lTbnFavyrmNZgnjdFGwu2iEbl0AWo0dKY0Pl87GXXZlJh
