10/7/19 12:19 p.m.
There's a difference between "acceptable" and "normal". One's at the threshold of the spec, one's in the middle.
Suprf1y
Suprf1y UltimaDork
10/7/19 12:53 p.m.
_ said:
People always jump to the oil rings. How about we try valve stem seals first, and that’s only after getting a leakdown test.
Because excessive oil consumption is almost never valve seals.
thedoc
thedoc GRM+ Memberand Reader
10/7/19 12:57 p.m.
In reply to RedGT :
Got it, but the PCV valve looked almost new.  Granted we have had the car for about a year.
Lof8
Lof8 GRM+ Memberand Dork
10/7/19 1:33 p.m.
I've had 3 miatas.  None burned any significant oil.
WonkoTheSane
WonkoTheSane GRM+ Memberand SuperDork
10/7/19 1:42 p.m.
My beater 96 is in the same boat, but, like TheRielDeal, I only loose about a quart every 1000 miles and it smokes under decel, so I'm assuming valve seals.
Replacing the pcv took me from a quart every fill up to that number, so it's likely not to be a single, $1.79 bullet..
Streetwiseguy MegaDork
10/7/19 1:46 p.m.
The original post said it burns a quart a week.  That is a bit meaningless.  Does your son drive it to school and home, putting a hundred miles a week on?  Does he drive to Nome Alaska once a week, putting five thousand miles on?
An engine burning oil at 200,000 miles generally means you either need to buy a case of oil, or pony up for a proper rebuild.
iceracer
iceracer UltimaDork
10/7/19 3:04 p.m.
In reply to Keith Tanner :
disagree to a point.  I had a car, not Miata, that smoked on deceleration.   New rings fixed it.
 valve seals will show up after idle, at least it did on my Neon.    No smoke on deceleration.
MJlWVFJe6jTEZPsg4coUVfbuPFGzYUrj8F6HBzp42VGy08bzZdIbc9IDFhGHB544
