geomiata
geomiata Reader
5/30/10 10:42 p.m.
My moms first generation BRG miata has developed a steaming problem. My mother was driving it on the highway and the temperature gauge went to full temp so she wisely pulled over and called me for help. I arrived and filled it up with water and we made it 4/5 of the way home before she pulled over to tell me that it was working fine and i could go to my house. At this point i steam poured out underneath her car and told her to shut it off. After a brief inspection i noticed that the water was not coming out of the overflow but seemed to be coming from somewhere underneath the intake (just a guess i saw no water escaping as the car was off). She said that the water temperature only went up when she stopped to tell me i could stop following her.
Probably causes?
Kia_racer
Kia_racer HalfDork
5/30/10 10:49 p.m.
Sounds like a water pump.
geomiata
geomiata Reader
5/30/10 11:17 p.m.
How hard is instalation of a new one?
MCarp22
MCarp22 Reader
5/30/10 11:54 p.m.
There are a bunch of coolant hoses that go to the throttle body and idle bypass valve, i would inspect them. There is also a rubber cap on the back of the head that is a fairly common point of failure if i remember right.
Tom Heath
Tom Heath Webmaster
5/31/10 1:15 a.m.
geomiata wrote: How hard is instalation of a new one?
Not too bad. Do a timing belt while you're in there. I struggled with the belt, but got it done in a day. I bet Keith could do it in 3(?) hours.
Good luck, you can do eet!
Woody
5/31/10 5:18 a.m.
Yeah, there are lot of small coolant hoses and it could be any one of them. Do them all at the same time.
mistanfo
mistanfo Dork
5/31/10 7:47 a.m.
Try pressurizing the system, see if you can see where it is coming from? Just to make sure it isn't the head gasket.
Keith
5/31/10 11:27 a.m.
http://www.miata.net/garage/CoolingSystemProblems.html <- includes details on the rubber plug.
I seem to remember there's a big one on the intake side of the block as well. I'l have to double-check details when I get to work tomorrow.
fastmiata
fastmiata Reader
5/31/10 2:54 p.m.
Usually when the plug on the back of the engine lets go, you will get a face full of coolant esp on the passenger side of the car. The motor then cools and allows you to drive a short distance to a repair shop where you have to show the guy how to fix it. Ask how I know. It has happened at least 3x to me over the years.
XzG30RcbU1T53YzmH3L8yyWlStSbvqDazWZgRQH85mrSJrKXibFESlQy1ZybLVRp
