flexi
flexi New Reader
2/16/14 7:44 p.m.
I have some exhaust mani studs I need to install. I have antiseize, should I apply this to the part of the stud that goes into the head? Or lube, or loctite? Sorry for such a simple question.
More basic, what is the best way to install a manifold stud? I understand the double nut trick, but how far in should the stud thread in? It shouldn't bottom out, right? Does one need to chase the threads on the stud?
Thanks!
Don49
Don49 HalfDork
2/16/14 9:14 p.m.
I always use Loctite and install them until the threaded part in the head is completely screwed in. I use the double nut trick also. No need to chase the threads unless you bugger them.
calteg
calteg Reader
2/16/14 9:27 p.m.
loctite on the stud, anti-seize on the nut. When I was doing my turbo install, I pulled out two studs that were inseperable from the nuts.
z31maniac
z31maniac UltimaDork
2/16/14 9:31 p.m.
Why does the stud need loctite?
pjbgravely
pjbgravely New Reader
2/16/14 10:54 p.m.
The stud needs to stay in , you can use graphite on the nut, it won't burn off.
flexi
flexi New Reader
2/17/14 8:55 p.m.
Thanks for the info. It really helps.
I have some unknown blue loctite in the garage, (label is unreadable now) but it has been subjected to temperatures well below freezing - is it ok to use?
D4qPyvSpEpQyKgEK0U0r4yL83heeqp9pIPlsIdnZAYJhlB1zqCZaacuipyxlvOLh
