Somebeach
Somebeach Reader
12/29/18 3:14 p.m.
I must have not searched correctly bc I am sure this has been covered but couldn’t  find what I wanted.
My new to me 1993  is leaking oil, the bottom of the CAS is covered so I know I need an new o ring.
The question is which one? Some people say OEM. Some say Vinton? I saw there is one on the flyin Miata site.  So which is the best to get?
Also should I do the valve cover gasket at the same time? I don’t see much oil leaking from it, but the whole back has oil on it so don’t know if that is all just from the CAS.
rustybugkiller
rustybugkiller HalfDork
12/29/18 4:33 p.m.
I think I bought mine at NAPA. I think the heat/time destroys them so anything you put in there will fail eventually. I did my valve cover and cas along with the timing belt. Do you know when it was replaced?
12/29/18 4:39 p.m.
No need to get fancy. They do last for a good amount of time.
You'll probably have to replace the valve cover gasket at the same time, as what destroys the CAS O-ring will also destroy the gasket. It'll be hard and crunchy.
cmcgregor
cmcgregor Dork
12/29/18 5:39 p.m.
It's also easier to get the CAS back on if you take the valve cover off, so like Keith said - be prepared with a new VC gasket as well.
I just did mine again today, it's fiddly but not too bad.
EvanB
EvanB GRM+ Memberand MegaDork
12/29/18 6:28 p.m.
I have a number of Viton o-rings laying around after I bought a pack to do one. Then I bought another pack when I had to do another car and found my original ones immediately after the job was done. If you PM me your address I'll mail you a couple.
Somebeach
Somebeach Reader
12/29/18 8:10 p.m.
In reply to rustybugkiller :
Have no idea when timing belt was done. Good idea to think about at same time though I am sure.
Somebeach
Somebeach Reader
12/29/18 8:12 p.m.
In reply to EvanB :
PM sent. Thanks for the generosity.
jKPbV9lXt6zQ0bSwgFsY690VsyrHVHTsJn7xPMFH66gttBQrDkNgRExHnawGWiHg
