imnezrider
imnezrider
7/5/11 8:50 a.m.
Just found this forum and need help with a car i just bought. Starts right up and idle is smooth (about 8-900 rpm). If I slowly increase speed to 1200-1300, it acts like it's going to die and of course it hesitates (bucks) if you try to drive it off in first gear. If I let it idle at the 800 level for about 2-3 minutes, everything is completely normal. As a wild guess, I'm thinking it's related to transition from open to closed loop. Checked for codes...none. I could really use some help on this. If necessary, email me at mdpar (at) beecreek.net. TIA
Sofa King
Sofa King Reader
7/5/11 9:10 a.m.
Put in new wires and plugs. Miatas will chew through both. Let us know if that helps.
iceracer
iceracer SuperDork
7/5/11 9:14 a.m.
O2 sensor sounds likely. Also coolant temperature sensor.
RossD
RossD SuperDork
7/5/11 9:19 a.m.
I second the wires and plugs. New NGKs for both and it took away the low rpm stumble on mine.
mthomson22
mthomson22 New Reader
7/5/11 9:29 a.m.
Mine exhibited similar symptoms but my problem got worse after the engine warmed up. Turned out to be the coolant temp sensor, so from what you are describing I think you can scratch that off the list.
sWsomOgDP7iEkcEuwQPzYbAMb1oatkc0Vh4r64L1k8ssWcnsQgMeCYIxYbrQKgo7
