Update time:
The car still smells like fuel after a fill up. The easy fix would be, of course, "Don't fill it all the way to the top, dumbass", but that wasn't good enough for me.
I finally broke down and ordered a replacement fuel filler hose, figuring that it has gotten old and brittle and was probably the source of a vapor or liquid leak.
I had a hard time finding the the right part number, as it wasn't as obvious as you would expect on the parts diagram. I called Mazdaspeed, confirmed that I was ordering the right item and they had it in my hands the next day for $31.
![photo Miata Fuel Hose 001_zpsn2uem4o3.jpg](http://i175.photobucket.com/albums/w146/Woodyhfd/2000 Miata/Miata Fuel Hose 001_zpsn2uem4o3.jpg)
FYI, my car is a 2000.
![photo Miata Fuel Hose 004_zpsjldewszj.jpg](http://i175.photobucket.com/albums/w146/Woodyhfd/2000 Miata/Miata Fuel Hose 004_zpsjldewszj.jpg)
I removed the trunk panel and fuel hose cover and loosened the clamps on the old fuel hose. I should note that the fuel gauge was reading about 3/4 full at this point. If you're doing this, make sure it's a bit lower than that.
This was the first sign that I might be on to something...
The fill pipe that feeds the hose is galvanized but there was a bit of rust at the seam where it was welded. Hmmmm...
![photo Miata Fuel Hose 008_zps5hfb44rr.jpg](http://i175.photobucket.com/albums/w146/Woodyhfd/2000 Miata/Miata Fuel Hose 008_zps5hfb44rr.jpg)
When I pulled the other end off of the fuel tank inlet, here's what I found:
Also note that you can see the fuel level just inside that pipe. I got very lucky that it was just low enough that I didn't end up with a trunk full of fuel when I removed that end of the hose.
I'm not sure whether to blame ethanol, age or some combination of both, but it was pretty clear that no amount of clamping force on the fifteen year old hose was going to result in a good seal.
Here's a good look at the inside of the hose ends:
![photo Miata Fuel Hose 019_zpslmhugdrz.jpg](http://i175.photobucket.com/albums/w146/Woodyhfd/2000 Miata/Miata Fuel Hose 019_zpslmhugdrz.jpg)
![photo Miata Fuel Hose 020_zpszmun7tgc.jpg](http://i175.photobucket.com/albums/w146/Woodyhfd/2000 Miata/Miata Fuel Hose 020_zpszmun7tgc.jpg)
I cleaned the tube ends up as well as I could with gray Scotch-Brite (I didn't want to make any sparks) and then coated them with grease to ease installation of the new hose, help it seal better, and to keep future corrosion at bay.
![photo Miata Fuel Hose 012_zpsyyvsyphn.jpg](http://i175.photobucket.com/albums/w146/Woodyhfd/2000 Miata/Miata Fuel Hose 012_zpsyyvsyphn.jpg)
With the new hose in place, all I have to do now is reinstall the cover and carpet.
![photo Miata Fuel Hose 016_zpsturgzx1r.jpg](http://i175.photobucket.com/albums/w146/Woodyhfd/2000 Miata/Miata Fuel Hose 016_zpsturgzx1r.jpg)
![photo Miata Fuel Hose 005_zpsrztnfh2b.jpg](http://i175.photobucket.com/albums/w146/Woodyhfd/2000 Miata/Miata Fuel Hose 005_zpsrztnfh2b.jpg)
![photo Fuel 004_zpsvyclmmwn.jpg](http://i175.photobucket.com/albums/w146/Woodyhfd/2000 Miata/Fuel 004_zpsvyclmmwn.jpg)
I'm not ready to proclaim "Problem Solved", but I have a pretty good feeling about this.
